Newbie Programming and Layout Questions
SimpleGuy
PostPosted: Fri Dec 19, 2008 11:29 am     Reply with quote
When I make my board, what is the best way to program the PIC? Have a port for my ICD-U40 like the demo board. Or is there a way to do it over the USB port, as I am putting on my board as well.
If I use the ICD-U40 like my demo board, it uses the SPI DI DO hardware pins. Can I just use a wired AND there, or will I need some kind of protection for my SPI bus?
If you can point me to a good source of information for someone using a PIC on their own design for the first time, that would be great.
thanks for any help
SherpaDoug
PostPosted: Fri Dec 19, 2008 3:18 pm     Reply with quote
For a first board I would avoid using a bootloader, and just use dedicated ISP programming pins. Read the section of the datasheet about ISP (In circuit Serial Programming).
PostPosted: Fri Dec 19, 2008 3:27 pm     Reply with quote
The follow documents show how to connect an ICD-U40 or ICD2 to your
own board:
See the CCS faq on the ICD-U40:
http://www.ccsinfo.com/faq/?45
Or see the Microchip ICD2 poster:
http://ww1.microchip.com/downloads/en/DeviceDoc/51265e.pdf
