Making hysteresis to A/D.
PostPosted: Fri Dec 19, 2008 9:11 am     Reply with quote
Using 8 bit A/D 0-255, want to use a pot. as a selector.
I want 4 step and don't want toggling between the step, therefore I want to use some hysteresis maybe 5-10 count.
Step without hysteresis.
0-63 step 1
64-127 step2
128-191 step3
192-255 step4
How to make the smartest implementation?
libor
PostPosted: Fri Dec 19, 2008 10:28 am     Reply with quote
I would just insert some 'neutral zones' between the 'steps'.
0-59 valid step 1
60 - 67 neutral zone
68-123 valid step2
124-128 neutral zone
129-191 valid step3
...etc
a reading in any neutral zone would result a no-change in the 'step'. (the previous state remains selected) a simple sequence of if()... structures will do.
However upon power-on you should initialize the step to the closest valid range.
PostPosted: Fri Dec 19, 2008 11:01 am     Reply with quote
Like this...
void readad(){
const int8 hyst=5;
int8 res;
 res=(int8)read_adc()&~0x03; //cutoff 2 bit
 if (res>0        && res<42+hyst){}  else
 if (res>42-hyst  && res<85+hyst){}  else
 if (res>85-hyst  && res<127+hyst){} else
RLScott
PostPosted: Fri Dec 19, 2008 1:20 pm     Reply with quote
Anonymous wrote:
Like this...
void readad(){
const int8 hyst=5;
int8 res;
No, I'm afraid this code will not implement hysteresis. The first "if" guarantees that the second "if" will never see a value of res<47, so there is no point in looking for "res>42-5". To implement hystersis, there must be some form of static memory of the previous range you were in, such as the variable "Range" in the following:
void readad(){
const int8 hyst=5;
int8 res;
 if (res<42-hyst)      Range = 0;
 else if(res<42+hyst)  Range = (Range<1) ? 0 : 1;
 else if(res<85-hyst)  Range = 1;
 else if(res<85+hyst)  Range = (Range<2) ? 1 : 2;
 else if(res<127-hyst) Range = 2;
 else if(res<127+hyst) Range = (Range<3) ? 2 : 3;
 switch(Range)
   case 0:  {} break;
   case 1:  {} break;
   case 2:  {} break;
   case 3:  {} break;
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
PostPosted: Sat Dec 20, 2008 2:47 pm     Reply with quote
Nice code, thanks :-)
