Can I have the same ISR for Timer3 & INT0?
BlueTower
PostPosted: Thu Dec 18, 2008 10:31 am     Reply with quote
Hi. How can I make the pc to jump to one ISR for #INT_TIMER3 & #INT_EXT. Can I do that? Can I have the same ISR for Timer3 & INT0?
Regards
ECACE
PostPosted: Thu Dec 18, 2008 10:47 am     Reply with quote
I don't believe you can have them go to the same ISR, but you could have the ISR's execute the same function, which would essentially be the same.
Granted, you probably wouldn't want to be printing from inside and ISR, but you get the point of what I mean?
#isr_1
Common_Function_1();
Common_Function_2();
#isr_2
void Common_Function_1()
printf("This is the 1st function common to ISR 1 and 2");
void Common_Function_2()
printf("This is the 2nd function common to ISR 1 and 2");
main()
printf("not in an ISR right now!");
A HW Engineer 'trying' to do SW !!! Run!!!
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Dec 19, 2008 7:26 am     Reply with quote
you can use the pre-processor directive
#int_global
void isr()
this will route the all interrupts to this function
but be careful using the compiler does not create the start up code and end code, and so if not being cautious, your system might fail
check with CCS help before you use this function.
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
baltazar_aquino
PostPosted: Fri Dec 19, 2008 6:10 pm     Reply with quote
Generally,in PIC MCUs, ISRs are in fact under one "big handler" if you are in the assembly language level. It is the programmer's responsibility to decode which particular part of the MCU hardware triggered the interrupt and then there's the segregation. CCS C just happened to be a higher level language and gives the programmer an easier life by providing segregated ISRs. I have the same suggestion as MicroManiac's.
