Internal EPPROM time need
sraiderk
PostPosted: Thu Dec 18, 2008 2:32 am     Reply with quote
I want to learn the following
read_eeprom(1); and
write_eeprom(1,1);
for these two statements in 18f452 internal eeprom area using,
How many time do you need separately, 1ms or 100us....
PostPosted: Thu Dec 18, 2008 5:25 am     Reply with quote
Not quite sure what you are asking?.
However, guessing that you are asking about the times these operations take. Then the answer to 1mSec, or 100uSec, is 'neither'.
The _read_ operation itself is almost instantaneous. The actual time needed for this, will depend on your clock rate. Basically, the compiler has to load the address needed into a couple of registers, set a flag, and read the result. A total of perhaps half a dozen instructions, so if your chip is running at 40MHz, under 1uSec.
The write, takes typically 4mSec. This is in the chip's data sheet. However this will vary, with supply voltage, temperature, and from chip to chip, so is not an 'exact' time.
sraiderk
PostPosted: Thu Dec 18, 2008 6:15 am     Reply with quote
OK, Ttelmah
I understood
rnielsen
PostPosted: Thu Dec 18, 2008 9:44 am     Reply with quote
Simply place the two commands in your code and after you compile it look at the List (.lst) file to see what assembly code has been generated. The Read command is straight forward. The Write command checks the WR bit inside the EECON1 register to see if the eeprom is finished writing. If it's not, it loops until it is. So, you can have a command immediately after the Write command and the eeprom will be successfully written before your code continues on.
Ronald
