How to do setting and use internal clock for PIC16F887
vinceykw
PostPosted: Wed Dec 17, 2008 9:26 pm     Reply with quote
As stated in topic. May I know how to do setting and use internal clock for PIC16F887?
Let say I want to set the internal clock running at 8MHZ.
Question 1
Do I need to write "setup_oscillator(OSC_8MHZ)" in order to use internal clock?
If yes, then is this the all setting for internal clock? or I miss some other part?
for #fuses do I need to type in INTRC ?
Question 2
How I going to run my internal clock?
I read from datasheet, it said the internal clock will automatically start when it goes into main().
Is it true? If not can anyone tell me how to run the internal clock?
Thx a lot ~~~ Very Happy
PostPosted: Wed Dec 17, 2008 9:46 pm     Reply with quote
Here is an example program. It uses the internal oscillator at 8 MHz.
It blinks an LED on pin B0.
#include <16F887.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, MCLR, NOLVP
#use delay(clock=8000000)
    output_high(PIN_B0);
    output_low(PIN_B0);
vinceykw
PostPosted: Wed Dec 17, 2008 9:52 pm     Reply with quote
Thx... dude~ If I face any question, I will be back~ Rolling Eyes
maaply
delay is not 500 ms
PostPosted: Thu Jan 22, 2009 5:34 am     Reply with quote
I tried above code for 16f727. the delay is not 500ms. I got approximatly 3 sec instead of 500ms. Can any one tell me, what I am doing wrong?
thanks.
PostPosted: Thu Jan 22, 2009 2:00 pm     Reply with quote
Post your compiler version.
