Pins refuse to go high? Code or hardware?
fvnktion
PostPosted: Fri Dec 12, 2008 5:01 pm     Reply with quote
Below is code that passes a byte of data and sets discrete preset port bits to the lower 4 values of the byte of data.
The code runs fine using Sim, but does not work well running in real time using ICD2.
When using Fast_io RA4 and RC0 are set but RA5 and RC1 are ignored.
When using standard io. It says that all are being set, but only RA4 and RC0 go high.
I am using vs. 4.057
Any suggestions?
PostPosted: Fri Dec 12, 2008 5:04 pm     Reply with quote
Post your PIC and post a small test program. Show the #include, #fuses,
and #use delay() statements, and the rest of the program.
fvnktion
#include <18F4520.h>
#fuses INTRC,NOPROTECT,MCLR,NOBROWNOUT,BORV45,NOWDT,WDT128,NOPUT,NOSTVREN,NODEBUG
#fuses NOLVP,NOWRT,NOCPB,NOWRTB,NOWRTC,NOCPD,NOWRTD,NOEBTR,NOEBTRB
#fuses NOXINST   //extended cpu
#bit RA4 = 0xf80.4
#bit RA5 = 0xf80.5
#bit RC0 = 0xf82.0
#bit RC1 = 0xf82.1
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
void byte_to_bit(char x){
//this does not work without fast io.
delay_cycles(1);
RA4 = x & 1;
RA5 = (x >> 1) & 1;
RC0 = (x >> 2) & 1;
RC1 = (x >> 3) & 1;
void main(){
char val2 = 1;
setup_oscillator(OSC_4MHZ|OSC_NORMAL);
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x00);
output_a(0);
output_b(0);
output_c(0);
//test standard pin sets high low
//works without fast io
delay_cycles(1);
output_high(pin_a4);
output_low(pin_a4);
delay_cycles(1);
delay_cycles(1);
output_high(pin_a5);
output_low(pin_a5);
delay_cycles(1);
delay_cycles(1);
output_high(pin_c0);
output_low(pin_c0);
delay_cycles(1);
delay_cycles(1);
output_high(pin_c1);
output_low(pin_c1);
delay_cycles(1);
//test the #bit define values
//woirks without fast io
RA4 = 1;
RA4 = 0;
RA5 = 1;
RA5 = 0;
RC0 = 1;
RC0 = 0;
RC1 = 1;
RC1 = 0;
while(1){
byte_to_bit(val2);
val2 = val2<<1;
}//while
}//main
PostPosted: Fri Dec 12, 2008 5:25 pm     Reply with quote
Post a description of the external circuits that are connected to these
pins. Also post the value of the components in the circuits.
SherpaDoug
PostPosted: Fri Dec 12, 2008 6:13 pm     Reply with quote
Being a hardware guy I would unsolder the PIC pin and see what it does without a load. DIPs and SOICs are easy, but some packages ARE hard to unsolder just one pin.
PostPosted: Fri Dec 12, 2008 6:32 pm     Reply with quote
Thanks for the input guys,
On the current board they are open circuit being tested with a meter.
Using a PIC18F4520 E\IP DIP 40. They are in a DIP socket and I have tried to switch one out with the same results.
I'll do some more trouble shooting on another board when i get back to the facilities.
It sure seems like it would work fine, but it has been one of those days.
PostPosted: Fri Dec 12, 2008 6:39 pm     Reply with quote
It's probably a RMW problem. (Read-Modify-Write).
How are you testing the result ? With a logic analzyer ? A Watch Window ?
PostPosted: Fri Dec 12, 2008 7:07 pm     Reply with quote
Hmmm, not familiar with RMW ( read modify write). If this is the problem, how can it be tested and modified?
I am using a watch window to view the alleged data output and then testing the actual with a meter.
Interestingly, sometimes the watch value is not even correct. I believe when I am using fast IO.
PostPosted: Fri Dec 12, 2008 8:57 pm     Reply with quote
Does this mean you are single-stepping the code ?
PostPosted: Sat Dec 13, 2008 7:09 am     Reply with quote
Obvious comment.
Do you have an external crystal?.
If not, you are turning off the oscillator, with:
You don't need/want this. You have already told the code to use the internal oscillator with the fuses, and clock statement....
donquixote
PostPosted: Sun Dec 14, 2008 8:43 pm     Reply with quote
Hi, guys,
I met the similar problem on pins not to being high or low with the output_high/output_low().
The chip is PIC24FJ128GA106, CCS Rev 4.80, and Mplab V8.15a. The testing code is attached below.
#include "24FJ128GA106.h"
#fuses HS, NOWDT, DEBUG, NOPROTECT, NOJTAG, IOL1WAY
   int c=0;
       do
   output_high(PIN_B3);
                //output_low(PIN_B3);
                }while(1);
Code is compiled correctly and downloaded into the chip via ICD2.
But the pin is not set to high when I use the Oscilloscope probe to test it.
Anyone could help me out?
Thanks in advance.
Don Quixote
PostPosted: Mon Dec 15, 2008 3:06 am     Reply with quote
Yes, PCD V4.083 is still mixing up PIC24FJ128GA106 SFR addresses
.................... output_high(PIN_B3);
05470: BCLR.B 2C6.3 ; THIS IS TRISA, TRISB WOUL BE 2C8
05472: BSET.B 2CA.3 ; CORRECT
Regards,
Frank
donquixote
PostPosted: Mon Dec 15, 2008 6:20 am     Reply with quote
Regards,
Frank
Hello, Frank,
Thanks for your checing.
And I also do the pin setting with assembly code to verify it this afternoon.
Seems the output_high function is wrong.
I would like to fix this bug with my own assembly code and also considering to migrate the code from CCS IDE to Mplab IDE with Microchip C compiler.
I am afraid of the unexpected bugs in the future.
Regards,
Don Quixote
PostPosted: Mon Dec 15, 2008 12:50 pm     Reply with quote
The best way to fix the bug is to define #bit SFR bits and assign values to it in C code, I think.
CCS has acknowledge the bug and said it's fixed in the next version.
You should expect some more PCD bugs, I fear.
Best regards,
Frank
