PIC16F877A CODE LCD
ewerebellatok
PIC16F877A CODE LCD
PostPosted: Sun Dec 14, 2008 11:13 am     Reply with quote
Hello experts,
I have problem to config this program. I used mplab to write this c code
and used CCS to compile the code. But how can I set the high speed
oscillator so that I can use external oscillator for pic16f877a. I can
simulate this code and it works fine but when I burn to PIC, lcd not display anything.
#define CRYSTAL_FREQ    16000000
#include <16F877A.h>
/* Include this file by inserting the line "#include <jonsinc.h>" at
the beginning of the C source code.  Or, if you prefer, you can embed it's
contents at the end of each of your 12C509H, 16F84H, 16F874.H, etc. files.*/
#case
#ifndef TRUE
#define TRUE 1
#ifndef FALSE
#define FALSE 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO 0
#ifndef HIGH
#define HIGH 1
#ifndef LOW
#define LOW 0
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#ifndef UP
#define UP 1
#ifndef DOWN
#define DOWN 0
#ifndef UCHAR
#define UCHAR char
#ifndef UINT
#define UINT long
#ifndef BIT
#define BIT short
#ifndef SCHAR
#define SCHAR signed int
#ifndef SINT
#define SINT signed long
#ifndef FLOAT
#define FLOAT float
// The six bus pins are defined here.
// this example happens to use PIC port B3, B4, B5, B6 for LCD data
// and port B5 for LCD ENABLE and port B6 for LCD RS.
#define LCD_D4          PIN_B1
#define LCD_D5          PIN_B2
#define LCD_D6          PIN_B3
#define LCD_D7          PIN_B4
#define LCD_EN          PIN_B5
#define LCD_RS          PIN_B6
// misc display defines
#define LINE_1          0x00
#define LINE_2          0x40
#define CLEAR_DISP      0x01
// prototype statements
#separate void LCD_Init ( void );
#separate void LCD_SetPosition ( unsigned int cX );
#separate void LCD_PutChar ( unsigned int cX );
#separate void LCD_PutCmd ( unsigned int cX );
#separate void LCD_PulseEnable ( void );
#separate void LCD_SetData ( unsigned int cX );
#separate void Delay5mS ( char cCnt );
// whatever pins you assign to the display
// MUST be in a bus that is a CCS type "standard_io".
#use standard_io ( A )
#use standard_io ( B )
#use standard_io ( C )
#use delay ( clock = CRYSTAL_FREQ )
static char cButtonPressed, cSkip, cButtonCount;
// code start here
void main ( void )
    char cX;
    cX = 1;                      // set number
    LCD_Init();                // set up LCD for 4-wire bus, etc.
    LCD_PutCmd ( CLEAR_DISP );      // clear screen
    LCD_SetPosition ( LINE_1 + 0 );    // set line and offset on line
    printf ( LCD_PutChar, "ewere ");   // display message
    LCD_SetPosition ( LINE_2 + 5 );   // set line and offset on line
    printf ( LCD_PutChar, "haha" );    // display message
    while ( 1 );                  // stop
/* SIX LCD-SPECIFIC FUNCTIONS ARE BELOW============================== */
    LCD_SetData ( 0x00 );
    delay_ms ( 200 );       /* wait enough time after Vdd rise */
    output_low ( LCD_RS );
    LCD_SetData ( 0x03 );   /* init with specific nibbles to start 4-bit mode */
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_SetData ( 0x02 );   /* set 4-bit interface */
    LCD_PulseEnable();      /* send dual nibbles hereafter, MSN first */
    LCD_PutCmd ( 0x2C );    /* function set (all lines, 5x7 characters) */
    LCD_PutCmd ( 0x0C );    /* display ON, cursor off, no blink */
    LCD_PutCmd ( 0x01 );    /* clear display */
    LCD_PutCmd ( 0x06 );    /* entry mode set, increment & scroll left */
    /* this subroutine works specifically for 4-bit Port A */
    LCD_SetData ( swap ( cX ) | 0x08 );
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );
    LCD_PulseEnable();
    if ( !cSkip )
        output_high ( LCD_RS );
        LCD_SetData ( swap ( cX ) );     /* send high nibble */
        LCD_PulseEnable();
        LCD_SetData ( swap ( cX ) );     /* send low nibble */
        LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    output_high ( LCD_EN );
    delay_us ( 3 );         // was 10
    output_low ( LCD_EN );
    delay_ms ( 3 );         // was 5
    output_bit ( LCD_D4, cX & 0x01 );
    output_bit ( LCD_D5, cX & 0x02 );
    output_bit ( LCD_D6, cX & 0x04 );
    output_bit ( LCD_D7, cX & 0x08 );
PostPosted: Sun Dec 14, 2008 1:30 pm     Reply with quote
Add #fuses and #use delay() statements. Example:
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay(clock=16000000)
Put the statements in the order as shown above. The #include statement
is first, then the #fuses and #use delay() go after it.
