Type conversion problem in PIC |
Posted: Sat Dec 13, 2008 9:50 am |
Hi
I have a function in my program that I should pass a char value to it. That char value contains in a int8 variable. So I convert the int8 variable to a char value,
int8 myvalue;
char val;
myvalue= 2;
val = (char)myvalue;
And I pass the "val" to another function and send the data out through UART.
But I am getting a blank where I should get the value of "val" . Other char values are displayed correctly. Is this a problem with the type conversion ??
Following are the functions used to transmit data through UART.
void TBE_isr(void) {
if (tx_counter != 0) {
putc(tx_buffer[tx_rd_index]);
if (++tx_rd_index > TX_BUFFER_SIZE) {
tx_rd_index = 0;
tx_counter--;
if (tx_counter == 0) {
disable_interrupts(INT_TBE);
void bputc(int c) {
int restart = 0;
restart = 1;
tx_buffer[tx_wr_index++] = c;
if (tx_wr_index > TX_BUFFER_SIZE) {
tx_wr_index = 0;
tx_counter++;
if (restart == 1) {
enable_interrupts(INT_TBE);
And in main,
createPacket(ptr,'f','f','0','0','f','f','0','0','b','1','0',val,
'5','0','0','0');
for (a=0;a<16;a++)
bputc(*(ptr + a)); //send the prepared packet
My output is,
Instead of value of "val" , I get a blank. |
Posted: Sat Dec 13, 2008 12:21 pm |
Quote: | int8 myvalue;
char val;
myvalue= 2;
val = (char)myvalue; |
You don't have to do this. In CCS, char and int8 are the same thing.
createPacket(ptr,'f','f','0','0','f','f','0','0','b','1','0',val, '5','0','0','0'); |
All the other values in the packet are ASCII bytes. You can see them
on a terminal window. But val does not have an ASCII number in it.
That's why you can't see it. Change it to this:
Posted: Sat Dec 13, 2008 11:07 pm |
Thanks for the help |
