10-bit result A/D
pvol
10-bit result A/D
PostPosted: Tue Dec 09, 2008 3:45 am     Reply with quote
hello everybody
i'm working on 16f876-7
and i want to storage a 10 bit result A\D in internal
eeprom
can i storage whole 10 bit number?/?
or i have to split in 2 bytes?//
PostPosted: Tue Dec 09, 2008 12:48 pm     Reply with quote
Read and bookmark the CCS FAQ page:
http://www.ccsinfo.com/faq
Look at this section:
Memory
How do I write variables to EEPROM that are not a byte?
Also, here is a post with sample code:
http://www.ccsinfo.com/forum/viewtopic.php?t=27405&start=5
pvol
PostPosted: Thu Dec 11, 2008 2:18 pm     Reply with quote
I have done an attempt to store these values
to some tables as you can see in this code.
Every 1ms (from interrupt) I will take 20 samples
for each table.
When samples =60 then interrupt disabled
and I get the numbers over 232.
...seems to work but not 100%.
Sometimes works great, sometimes confused,
and "pause" then start again.
Do I have fault somewhere?
#include <16F877.h>
#device ADC=10
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#use RS232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
int count=0;
int16 A[20];
int16 B[20];
int16 C[20];
int16 D[20];
int16 E[20];
int16 F[20];
int flag=1;
int i=0;
#int_RTCC
void   RTCC_isr(){
set_RTCC(100);
   count++;
   if(count<=20){
        set_adc_channel( 0 );
        delay_us(50);
        A[i] = read_ADC();
        set_adc_channel(1);
delay_us(50);
        B[i]=read_ADC();
        i++;
        if(i>=19)
           i=0;
   if((count>20)&&(count<=40)){
delay_us(50);
        C[i] = read_ADC();
        set_adc_channel(1);
delay_us(50);
        D[i]=read_ADC();
        i++;
        if(i>=19)
           i=0;
   if((count>40)&&(count<=60)){
delay_us(50);
      E[i] = read_ADC();
        set_adc_channel(1);
delay_us(50);
        F[i]=read_ADC();
        i++;
        if(i>=19){
         i=0;
           flag=0;
           count = 0;
    return;
void main (void){
   set_tris_a(0xff);
   set_tris_b(0x00);
   setup_adc_ports( AN0_AN1_AN3 );
   setup_adc(ADC_CLOCK_DIV_32);
   setup_counters(RTCC_internal,RTCC_div_16);
   set_RTCC(100);
   set_tris_c(0x01);
    enable_interrupts (INT_RTCC);
   enable_interrupts( global);
    PORTC=0x00;
   while(TRUE){
        while(flag);
      disable_interrupts(INT_RTCC);
      for(i=0;i<=19;i++){
 i=0;i<=19
         printf ("%ld\n",A[i]);
         printf("%ld\n",B[i]);
      for(i=0;i<=19;i++){  i=0;i<=19
         printf ("%ld\n",C[i]);
         printf(" %ld\n",D[i]);
      for(i=0;i<=19;i++){ einai i=0;i<=19
         printf (" %ld\n",E[i]);
         printf("%ld\n",F[i]);
      flag=1;
      count=0;
      set_RTCC(100);
      enable_interrupts(INT_RTCC);
PostPosted: Thu Dec 11, 2008 3:36 pm     Reply with quote
You are not using the internal EEPROM at all...
pvol
PostPosted: Fri Dec 12, 2008 1:00 am     Reply with quote
Thanks for answer!
Yes, I know that!!
Is it wrong to do it that way??
