Change fuses
SLF
Change fuses
PostPosted: Mon Dec 08, 2008 11:08 am     Reply with quote
Hi together!
I need to change the fuses during my program between HSPLL and INTHS with a PIC 18F2550, because of the power consumption.
In HSPLL mode I need the USB in FullSpeed with a 20MHz Osc (PLL5) and CPUDIV1.
In INTHS I need only the Internal Oszillator with 2MHz.
I this possible to do?
I tested this code, but I think it doesn't work:
Switch to HSPLL:
read_configuration_memory(0x300000,data,12);
bit_set(data[1],0);
bit_set(data[1],1);
bit_clear(data[1],2);
bit_set(data[1],3);
write_configuration_memory(data,0x300000,12);
setup_oscillator(OSC_2MHZ);
#asm
   BSF 0x0F6F.2 // FSEN
#endasm
Switch to INTHS:
bit_set(data[1],0);
bit_set(data[1],1);
bit_set(data[1],3);
#asm
   BcF 0x0F6F.2// FSEN
#endasm
My compiler version is 4.073
PostPosted: Mon Dec 08, 2008 11:29 am     Reply with quote
Problem is that most fuses, are only read when the chip boots up.
Remember also, that the write life of the configuration memory, is relatively limited. Not a problem if you change a bit every few weeks, but a major problem if you change it more often....
Don't do this.
Use the chips oscillator switching ability instead. This is what it is there for...
Look at the options in the setup_oscillator command.
SLF
PostPosted: Thu Dec 11, 2008 4:25 am     Reply with quote
Thanks a lot!
That's much easier and it works now fine!
