donquixote
Joined: 21 Jul 2008 Posts: 15 Location: Shanghai, China
"Solved" Code Compiling with Ccsc.exe in Mplab IDE |
Posted: Thu Dec 04, 2008 4:34 am |
Hello, guys,
I am trying to compile the code in Mplab IDE with calling Ccsc.exe , which is compiled successfully in CCS Rev 4.080.
And I have checked some topics on code compiling with Ccsc.exe in Mplab IDE, only the main.c is included in the source file of project and other .h and .c files are added into the other files directory according to the previous suggestion.
The files structure is shown below,
--Source files
---main.c
--Header files
---24FJ128GA106.h
---aa.h
---variables.h
--Other files
---2402.c
---bb.c
---cc.c
But I met some errors during compiling.
The 2402.C is called in my main.c file, but when I compiled it in Mplab IDE the i2c functions could not be recognized by the compiler. And the pins definitions are not recognized by the compiler too.
*** Error 100 "D:\Program Files\PICC\drivers\2402.C" Line 51(5,49): USE parameter value is out of range Not a number: PIN_C4
*** Error 12 "D:\Program Files\PICC\drivers\2402.C" Line 57(27,28): Undefined identifier PIN_C3
*** Error 12 "D:\Program Files\PICC\drivers\2402.C" Line 58(27,28): Undefined identifier PIN_C4
*** Error 12 "D:\Program Files\PICC\drivers\2402.C" Line 63(13,14): Undefined identifier -- i2c_start
*** Error 12 "D:\Program Files\PICC\drivers\2402.C" Line 64(19,20): Undefined identifier -- i2c_write
*** Error 12 "D:\Program Files\PICC\drivers\2402.C" Line 65(12,13): Undefined identifier -- i2c_stop
And the following is the code in 2402.C
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
BOOLEAN ext_eeprom_ready() {
int1 ack;
i2c_start(); // If the write command is acknowledged,
ack = i2c_write(0xa0); // then the device is ready.
i2c_stop();
return !ack;
Why the compiler could not recognize the i2c functions ?
And what are the configurations I should do to compile the code in Mplab IDE with calling Ccsc.exe and then program the target chip in IDE via ICD2.
BTW, when I want to import the .hex file generated by the CCS IDE to Mplab IDE and then try to program the target chip, I met the checksum error as following,
The line checksum on line 2 of the hex file is incorrect; the hex file appears to have been corrupted.
:040000001CF2000400
Any solution on them to help me out?
Thanks in advance and appreciated. _________________ Don Quixote
Posted: Thu Dec 04, 2008 1:41 pm |
Make a small test project with a main source file that #includes the
2402.c file.
For example, this program could be called Test.c and it could be in
a project called "Test". In MPLAB, only the Test.c file would be added
to the project. Then compile the project. It should compile OK.
Code: | #include <16F877A.H>
#include <2402.c>
int8 c;
init_ext_eeprom();
write_ext_eeprom(0, 0x55);
c = read_ext_eeprom(0);
Try this with your PIC. See if you can make it work. |
donquixote
Posted: Wed Dec 10, 2008 4:23 am |
PCM programmer wrote: | Make a small test project with a main source file that #includes the
2402.c file.
#include <2402.c>
int8 c;
init_ext_eeprom();
Thanks . It works. _________________ Don Quixote |
