Cheap measurement for R, C and L. |
Posted: Tue Dec 09, 2008 3:13 pm |
Any hints for this project?
Want to make a small and cheap measurement for R, C and L.
I think using a opamp for interface to the pic. And a fet to discharge the C or L.
Measure for C can be "3*tau" = 95% of the input. And for L the same but reverse.
Start to make sure the L or C is discharged then disconnect the fet, now the current will grove in the circuit. Start the A/D and wait for the U to be 95% of the Ui. There i got my 3tau.
R=1k / C=1u /Ui=5 -> 3*1k*1u*2*3,14=18,84ms
Will this simple method work? |
SherpaDoug
Posted: Tue Dec 09, 2008 3:20 pm |
Check out Microchip application note AN512 for a glimpse at how much can be done with how little hardware. AN512 can measure R or C. Measuring L with take a little thought. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Dec 10, 2008 1:41 am |
Is there any hints for this? |
crystal_lattice
Posted: Wed Dec 10, 2008 11:15 am |
Create a oscillator circuit with RCL combo, with the L or the C as the variables and measure the frequency. There is a circuit diagram here: http://electronics-diy.com/lc_meter.php
Edit: Here is a more complete link:http://ironbark.bendigo.latrobe.edu.au/~rice/lc/index.html |
