Using port B as analog input |
Posted: Mon Dec 08, 2008 3:44 pm |
Hi, I am using a PIC16F767. I'm trying to read analog input from a potentiometer into Pin 25 which is RB4/AN11. I'll provide my code. When I print the value at this pin I get values close to 100, but they just stay there as I turn the potentiometer. When I set the analog channel to AN1 it works beautifully. Does anyone know how to get access to the analog inputs, which share pins with port B?
Header file:
Code: | #include <16F767.h>
#device ICD=TRUE
#device adc=8
#FUSES RC //Resistor/Capacitor Osc with CLKOUT
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES BORSEN //See Datasheet
#use delay(clock=500000)
#use rs232(debugger)
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
Actually code
Code: | #include "\\engin\rvelez1\celeborn\class09\rvelez1\E72\Final Project\ServoControl\CommandViaPOT.h"
int16 getPWM(int16 pulseWidth)
return (int16)( ((long)pulseWidth*500000) / ((long)16*1000000) );
int POTreading;
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,155,1);
setup_ccp1(CCP_PWM);
setup_vref(FALSE);
setup_oscillator(OSC_500KHZ|OSC_INTRC);
setup_adc_ports(ALL_ANALOG|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
set_adc_channel(10);
//maxWidth=2700;
POTreading=read_adc();
printf("Here is the POT %d.\n",POTreading);
delay_ms(300);
Posted: Mon Dec 08, 2008 3:49 pm |
#use delay(clock=500000) |
Is this real ? Do you really have a resistor and capacitor connected to
the Osc1 pin on the PIC ?
If you don't, I suspect that you really want to use the INTRC_IO fuse,
and set the #use delay() for 8 MHz.
Also, is this a hardware project, or is it Proteus ? |
robyvelez
Posted: Tue Jan 20, 2009 10:37 am |
I've since changed those settings. My header file looks like this:
#device ICD=TRUE
#device adc=10
#use delay(clock=8000000)
And my code looks this.
Code: | #include "\\engin\rvelez1\celeborn\class09\rvelez1\E72\Final Project\TestBoard\testAnalog.h"
setup_spi(FALSE);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
set_adc_channel(12);
printf("Reading %Lu.",read_adc());
I'm still having the same problem. I can't read any analog ports that are also port b. I just get junk and random readings.
Also something weird when I place an input on the pin for AN12 i get nothing, but when I place the input on the pin for AN4 it reads it just fine. Same thing happens for AN11 and AN3, AN10 and AN2, AN9 and AN1, and AN8 and AN0. |
Posted: Tue Jan 20, 2009 2:35 pm |
Try a simple test program like this (get rid of most of your code) and see
if it works. If it doesn't work, then post:
1. Your compiler version.
2. A description of the circuit connected to AN12 (pin B0).
Here's the test program:
#device adc=10
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT
int16 adc_value;
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_16);
delay_us(20);
adc_value = read_adc();
printf("%LU ", adc_value);
robyvelez
FIXED! (I think/hope) |
Posted: Tue Jan 20, 2009 8:13 pm |
Thanks a lot for the reply. I tried the sample code you presented, but that still didn't work, and then I got to thinking about the compiler version.
I tried using a computer with a more updated version of the compiler. I'm an engineering student at a college and the computer I've claimed to use for my project had an old version of PIC C. Using a new version of the compiler the program seems to works fine. I'm going to ask ITS to update the version of PIC C on this computer and try it tomorrow, but I think using a more up to date compiler will do it. If not I'm sure you'll hear back from me again. |
Posted: Sat Jan 24, 2009 7:39 am |
Hi
Remove the line setup_spi(false); this it not right.
Its the same as setup_spi(0) which is:
#define SPI_CLK_DIV_4 0
