pasini
Joined: 12 Dec 2005 Posts: 50 Location: Curitiba - Brazil
| Another problem with timer1 - PIC16F913 |
Posted: Mon Dec 08, 2008 10:36 am |
MPLAB 8.10 / CCS 3.223 / PIC16F913
Hi I have a PIC 16F913 with 32kHz crystal. I want the timer1 to be interrupted every 250ms to verify PIN status and count 4ticks to make 1second. If I set the timer1 clock to be the same as the internal clock, the MCU is not interrupted, whereas if I set it to external clock it is interrupted. Timer1 is also a base clock for the LCD. Timer1 must run during sleep, and wakeup the PIC.
The problem seams to be with T1CON. What I am doing wrong ?
My code is:
#int_timer1
void isr_timer1()
set_timer1(64680); // 250ms
deb = deb << 1;
if(!input(PIN_A0))
deb |= 1;
if(deb)
{ msec++;
if(msec>=4) //32)
{ msec=0;
seg++;
if(seg>59)
{ seg = 0;
min++;
atual=0;
// GravaHorario();
if(min>59)
{ min = 0;
hora++;
// GravaHorario();
// if(hora>99999)
// hora=0;
// atual = 0;
Inside main routine:
set_timer1(64680); //250ms
//T1CON = 0b10001111; // pre-scaler=1:1
//T1CON = 0b10101111; // pre-scaler=1:4
T1CON = 0b10111111; // pre-scaler=1:8
enable_interrupts(GLOBAL); |
Thanks for any help,
Paisni |
Posted: Mon Dec 08, 2008 10:56 am |
First your count.
Are you sure you have a '32KHz' crystal, not 32.768KHz. The latter is the 'standard' for watch crystals.
Then:
Timer runs off 32768Hz/8.
4096 counts per second.
1/4 second = 1024 counts.
Preload required is 65536-1024 = 64512
Then, use the CCS functions to setup the timer.
setup_timer1(T1_EXTERNAL|T1_CLK_OUT|T1_DIV_BY_8);
Set this _before_ you preload the counter. Otherwise the counter may have advanced much faster than expected in the intervening instructions.
To wake the chip up from sleep with the timer, it _must_ run from the external clock. The internal clock _stops when the chip sleeps. This is why you won't get the interrupt, if you use the internal clock.
Add your offset to the timer value, rather than just loading it. Wake up from sleep, takes quite a ong time, since the chip waits for the master oscillator to stabilise, before waking. Hence the timer may already have counted, before your reach the ISR.
