Lykos1986
Continuous interrupt |
Posted: Sun Dec 07, 2008 11:01 am |
Hi! May I have your help? I am trying to set up an interrupt from the serial port using a PIC 16F877. The problem is that the PIC always goes to the interrupt service routineā¦
What I have to do?
#include <16f877A.h>
#FUSES XT, NOWDT, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use delay (clock = 4000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,stream=module)
#int_rda
void serial_isr()
disable_interrupts(int_rda);
disable_interrupts(global);
output_high(led3);
output_low(led3);
enable_interrupts(int_rda);
enable_interrupts(global);
return;
sleep();
Posted: Sun Dec 07, 2008 11:25 am |
For why it constantly goes to interrupt routine...
http://www.ccsinfo.com/forum/viewtopic.php?t=36800
Also, in the int_rda routine
remove enable and disable interrupt lines, already taken care of by the compiler..
remove the return, already taken care of by the compiler.
Remove the delay, set a flag instead and process in the main loop
Example main loop pseudocode:
main()
Enable_interrupts(int_rda)
Enable_interrupts(global)
set flag false
While (1)
if flag from interrupt set
set flag false
blink LED here
FvM
Posted: Sun Dec 07, 2008 1:58 pm |
Basically, the interrupt flag has to be reset in the ISR by reading from the UART, otherwise it must repeat continuously
Why don't you simply try the CCS programming examples? |
