How can I write and read mcu id location
cchappyboy
PostPosted: Fri Dec 05, 2008 4:51 pm     Reply with quote
For example : PIC18F458, its id location on 200000H to 200007H
How can I write to this location. Is that #id directive? But how can I write to these 8 bytes ?
How can I read this id memory? Which command should I use ?
PostPosted: Fri Dec 05, 2008 5:42 pm     Reply with quote
Use #id to put values in the ID locations. Then try this function to read it:
http://www.ccsinfo.com/forum/viewtopic.php?t=20257&start=1
The Device ID only has two locations, as shown in the sample code.
But the "ID" has 8 locations. So you need to change the example
code to call it 8 times (instead of 2). Also, change the address so it's
for the "ID" location.
I have not tested these suggested changes in hardware.
