harshanahnd
UART data transmit problem |
Posted: Wed Dec 03, 2008 11:42 pm |
I develop a small program to get data through USB on a 18F4550 pic and transmit that data over UART of the PIC. But when I check the data that is coming from UART it always read as 0x00. Following is the code I used.
int8 in_data[4];
switch (in_data[1])
case 0:
a = (char)(in_data[3]);
printf("Temperature: 0x%X ", in_data[3]);
The value in variable in_data[3] is the one I want to print. I am getting that value from a USB packet from my PC. I checked with putting that value to a return USB packet to my PC and it correctly gives the value I previously set. So in_data[3] has my value but when I print it, it gives 00.
What could be the problem?
Thanks in advance. |
Posted: Thu Dec 04, 2008 1:05 am |
Comment out the USB code. Load the array with some sample data.
Send it to the PC through the serial port. This will test if the RS-232
is working OK.
Or,
1. Look closely at your code to see if byte 3 is really being loaded by
the USB routine.
2. Pre-load the array with some non-zero data, such as 0x12, 0x34, 0x56, 0x78, etc., instead of filling it with zeros. Then get data from
the USB device. Then send it to the PC. If byte 3 has 0x78 in it, then
you know that your USB code is not loading the array correctly.
3. Do other tests of this type, to verify your code operation. |
Posted: Sun Dec 07, 2008 10:30 pm |
I did all the tests. UART is working perfectly. The problem is with the USB data. When I manually set a value as you have mentioned, it got displayed correctly. Then what I did was I put the received USB packet back to the PC and interpret it in PC. Following is the code,
out_data[0] = in_data[0];
out_data[1] = in_data[1];
out_data[2] = in_data[2];
out_data[3] = in_data[3];
usb_put_packet(1,out_data,4,USB_DTS_TOGGLE);
Here the value is correctly displayed on PC. (the value in in_data[3]). I cant figure out the reason why is it not getting display from UART.
Thanks. |
Posted: Sun Dec 07, 2008 11:36 pm |
Did you try doing it like this ? (Add the code shown in bold)
for(i = 0; i < 4; i++)
printf("%X ", out_data[i]);
printf("\n\r");
