Why can I not compare two arrays of 4 elements ?
t90
PostPosted: Wed Dec 03, 2008 9:26 pm     Reply with quote
The value of my compare function doesn't return the truth value although
I tried every solution but it still doesn't return the right value. Someone please help me!
Here is my code:
First solution:
int compare2(int8 a[4],int8 b[4]){
   //compare the fourth element first because it storage the highestvalue   //in the array,the lowest value is the first element
   if(b[3]<a[3]){
      return 1;
   }else if(b[3]==a[3]){
      if(b[2]<a[2]){
         return 1;
      }else if(b[2]==a[2]){
         if(b[1]<a[1]){
            return 1;
         }else if(b[1]==a[1]){
            if(b[0]<a[0]){
               return 1;
            }else if(b[0]==a[0]){
               return 3;
            }else
               return 2;
         }else
            return 2;
      }else
         return 2;
   }else
      return 2;
Second solution:
int compare2(int8 *a, int8 *b)
int index = 3;
for (count = 0; count < 4; count++)
if (b[index] < a[index])
return 1; // Less
else if (b[index] > a[index])
return 2; // Greater
index--;
return(1); // Equal
Third solution:
int compare2(int8 a[4], int8 b[4])
int index = 3;
return 1; // Less
index--;
return(1); // Equal
PostPosted: Wed Dec 03, 2008 9:48 pm     Reply with quote
You are a newbie. Consider this idea before you invent new code:
Most of the simple things in C programming already have a function
to do them. This includes the idea of "comparing two arrays".
When you want to do a simple thing, first you should look at a list of
common C functions. Look to see if a function exists to solve your
problem. Use Google to find the list.
http://www.ccsinfo.com/forum/viewtopic.php?t=36476&highlight=memcmp
http://www.ccsinfo.com/forum/viewtopic.php?t=36705&highlight=memcmp
Wayne_
PostPosted: Thu Dec 04, 2008 9:04 am     Reply with quote
I gave you that second piece of code and I have also told you that I made a couple of mistakes in it. Below is the corrected code which I had already sent you.
  int index = 3;
  int count;  // This is where the first fault was
      return 1; // Less
    index--;
  return(3); // Equal (This is where the second fault was)
I have now tested this and sent you my test code which proves that it works.
If you are still having problems with it then feel free to post here or PM me to try and get it sorted. Smile
PCM programmer, Yes there are functions to compare arrays, in paticular strings. What t90 has are 2 arrays of BCD values and he needs to compare in the following order index 3 then index 2 then index 1 and finaly index 0. I found it easier to provide him with this code than try and find a function to do what he wants.
It may be possible that memcmp or even strcmp will give the correct results but it would have taken me longer to work it out LOL Smile
If he was to re-arange his data then the compare functions may provide a better solution, I have no idea if he can do this though!
Anyway, this code does work for what he wants, If he annot get it to work then he must be doing something wrong!
