Transmit and receive unicast message
evios
PostPosted: Mon Dec 01, 2008 8:40 pm     Reply with quote
Within the digit.h file, I declare
#define EXP_OUT_ENABLE PIN_C1
#define EXP_OUT_CLOCK PIN_B4
#define EXP_OUT_DO PIN_B5
#define NUMBER_OF_74595 3
#include<74595.c>
For the base station, named BS.c:
#include<18F4620.h>
#fuses HS,NOWDT,NOLVP,PUT,NOBROWNOUT
#use delay(clock=10000000)
#use rs232(xmit=PIN_C6, rcv=PIN_C7, baud=9600)
#define COORDINATOR 1
#include "em260.h"
#include "ember_utilities.c"
#include<digit.h>
But when I compile BS.c it comes out with the error for the 74595 library file:
The error file:
But I already define it at digit.h for the PIN_DO.
Anyone can help? Thanks
treitmey
PostPosted: Tue Dec 02, 2008 9:35 am     Reply with quote
Can you put the include for digit.h before the include for 74595?
The compiler works from top down.. and doesn't know about the digit.h
when its compiling the 74595 part,.. so it doesn't know about the define.
PostPosted: Tue Dec 02, 2008 10:55 am     Reply with quote
He already is.
The 74595 include is immediately after his pin define, in the 'digit.h' file.
It should work.
However, the error message, suggests that something is wrong, possibly _in_ the define.
Try retyping it. It looks as if the define may have a hidden character in the pin number. You can get this sort of behavious/message, if there is an invisible character inside the text line.
It compiles fine for me (added a 'main', and a data definition for the array of bits to send).
treitmey
PostPosted: Tue Dec 02, 2008 3:29 pm     Reply with quote
Of course your right.
behavious Smile
http://www.urbandictionary.com/define.php?term=behavious
PostPosted: Tue Dec 02, 2008 4:05 pm     Reply with quote
Don't chips do this all the time!.... Smile
