How to change the value of the array via function?
t90
PostPosted: Tue Dec 02, 2008 2:09 am     Reply with quote
I work in project that use PIC18f4550. In my project I implement one function to copy value from 1 variable to 1 member in 1 array consist 20 member which 1 member is a char variable has 4 member. But I can't copy the value. Someone has seen my problem. please solve for me. Thank you!
Here my code:
//my array
struct Node{
   int time[4];
static struct Node tim[20];
static BYTE temp[4];
//function copy
void bcopy(int a[4],int &b0,int &b1,int &b2,int &b3){
   b0=a[0];
   b1=a[1];
   b2=a[2];
   b3=a[3];
   return;
//another function copy
void bcopy1(int8 a[4]){
   temp[0]=a[0];
   temp[1]=a[1];
   temp[2]=a[2];
   temp[3]=a[3];
   return;
void main(){
     int a1[4];
   int a2[4];
   int a3[4];
   int a4[4];
   int a5[4];
   int a6[4];
   a1[0]=0x00;
   a1[1]=0x00;
   a1[2]=0xFF;
   a1[3]=0x7F;
   a2[0]=0x00;
   a2[1]=0x01;
   a2[2]=0x02;
   a2[3]=0x03;
 //the value not change        bcopy(a1,tim[header].time[0],tim[header].time[1],tim[header].time[2],tim[header].time[3]);
   bcopy(a1,temp[0],temp[1],temp[2],temp[3]);
Sad Surprised
PostPosted: Tue Dec 02, 2008 3:40 am     Reply with quote
You don't say 'what compiler version'.
Now, you are using reference parameters, which are a sort of 'halfway house', between using pointers, and the normal pass by value. I'd not use reference paramters for this. The manual says _limited support_ for reference parameters, and though they do work for a simple variable, for an array item, I'd not be at all surprised if they gave trouble.
I'd stick to 'standard' C, and pass the addresses.
So:
[code]
//function copy
void bcopy(int a[4],int * b0,int * b1,int * b2,int * b3){
*b0=a[0];
*b1=a[1];
*b2=a[2];
*b3=a[3];
//and call with
bcopy(a1,&temp[0],&temp[1],&temp[2],&temp[3]);
[/copy]
Wayne_
PostPosted: Tue Dec 02, 2008 3:45 am     Reply with quote
You need to pass the address of the var/array you want to set to the function, I think you have gotten a little confused about pointers. As you are using arrays a better method would be:-
void bcopy(int *a, int *b)  // This function requires 2 pointers
  int i;
  for (i = 0; i < 4; i++)
    b[i] = a[i]; // or *b++ = *a++; should work as well
void main(){
     int a1[4];
   int a2[4];
   int a3[4];
   int a4[4];
   int a5[4];
   int a6[4];
   a1[0]=0x00;
   a1[1]=0x00;
   a1[2]=0xFF;
   a1[3]=0x7F;
   a2[0]=0x00;
   a2[1]=0x01;
   a2[2]=0x02;
   a2[3]=0x03;
  bcopy(a1, tim[header].time); // pass the address of a1 and tim[header].time ti the function
  bcopy(a1, temp);  // pass the address of a1 and temp
  // Specifying just the name of the array will pass the address of that array
// Some people prefer to use
// bcopy(&a1[0], &temp[0]); // & means address of so &a1[0] is the address of the first index of the array
t90
PostPosted: Tue Dec 02, 2008 8:55 am     Reply with quote
Thank you very much! But the values displayed in LCD isn't values I have input in my array. Here is my entire code. Please see it for me!.
#include "18f4550.h"
#device HIGH_INTS=TRUE
#fuses HS,NOPROTECT,NOLVP,NODEBUG,NOWDT
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
#include "ewl_glcd.c"
#include "ewl_realtime.c"
char glcd_buff[128];
int a[4];
char out[10];
struct Node{
   int time[4];
  int i;
    *b[i]++ = *a[i]++; // or *b++ = *a++; should work as well
// External interrupt xac dinh boi tin hieu goi ve tu chip RealTime clock
#int_ext2
void rtc_card_isr()
   read_time();
   glcd_fill_area(0,0,127,12,OFF);
   sprintf(glcd_buff,"%Lu-%u-%u %U:%02U:%02U\n",2000+ds1307_regs[YEAR_REG],ds1307_regs[MONTH_REG],
               ds1307_regs[DATE_REG],ds1307_regs[HOURS_REG],ds1307_regs[MINUTES_REG],ds1307_regs[SECONDS_REG]);
   glcd_text57(0,0,glcd_buff,1,ON);
   int header;
   int c[4];
   set_time();
   header=0;
   a[0]=1;
   a[1]=2;
   a[2]=3;
   a[3]=4;
   c[0]=0xFF;
   c[1]=0xFF;
   c[2]=0x01;
   c[3]=0x01;
   set_tris_e(0x00);
   set_tris_d(0x00);
   set_tris_b(0xfc);
   set_tris_c(0b10000000);
   setup_adc(ADC_OFF);
   set_tris_a(0x00);
   glcd_init(ON);
   glcd_fillScreen(OFF);
   // LCD
   set_tris_c(get_tris_c()&0b11111011);
   setup_timer_2(T2_DIV_BY_16,127,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(500);
   bcopy(a,tim[1].time);
   enable_interrupts(INT_EXT2);
   init_DS1307();
   //set_tris_b(get_tris_b() | 0xF0);
   set_tris_e(0x00);
   sprintf(out,"%u-%u-%u-%u ",tim[1].time[0],tim[1].time[1],tim[1].time[2],tim[1].time[3]);
   while(1){
      glcd_text57(0,30,out,1,ON);//display the value in graphic LCD but the value is wrong.
Wayne_
PostPosted: Tue Dec 02, 2008 9:01 am     Reply with quote
You have changed the line
It should be
b[i] = a[i];
or
*b++ = *a++;
Not a mixture of both!
t90
Thank you Wayne_
PostPosted: Tue Dec 02, 2008 9:49 pm     Reply with quote
It's well active. Thank you!
