clock frequency
praveen_karimilla
clock frequency
PostPosted: Tue Dec 02, 2008 3:05 am     Reply with quote
how to set the clock frequency to 4mhz can any one help with PIC c
Rohit de Sa
PostPosted: Tue Dec 02, 2008 4:57 am     Reply with quote
The frequency of the PIC is set by the crystal attached to its OSC pins. If you put a 4MHz crystal, and set (one of) your fuses to 'XT', you can use this crystal.
Some PICs also have an internal oscillator preset at 4MHz, or a dual speed oscillator, or a selectable-speed oscillator. You need to use the 'INTRC' or 'INTRC_IO' fuses to do this.
If you have a multi-speed internal oscillator have a look at the 'setup_oscillator' instruction.
Rohit
SherpaDoug
PostPosted: Tue Dec 02, 2008 9:48 am     Reply with quote
Read the manual about the #use delay() preprocessor directive. It is simple for the older chips, but gets complex for the newer chips with many clock options. Also read clock section of the datasheet for your PIC.
