H. Schleyer Guest
| I2C PIC16F876 PCF8583 24C16 - Problem |
Posted: Wed May 08, 2002 1:41 am |
Hi PIC-folks,
I've trouble with reading the time of the 8583.
Address-Pin PCF8583 -> +5V
Address-Pins 24C16 -> GND (As I know: not connected internally, anyway)
I got wrong data when using read_pcf(4) (hours).
reading seconds ,days etc works fine!
Writing hours works, too.
Reading and writing EEProm: no problem.
Am I mad?
Here's the code:
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
//#endif
#use i2c(master,sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE 2048
#define hi(x) (*(&x+1))
void init_ext_eeprom() {
output_float(eeprom_scl);
output_float(eeprom_sda);
#separate
void write_ext_eeprom(long int address, byte data) {
i2c_start();
i2c_write((0xa0|(byte)(address>>7))&0xfe);
i2c_write(address);
i2c_write(data);
i2c_stop();
delay_ms(11);
#separate
byte read_ext_eeprom(long int address) {
byte data;
i2c_start();
i2c_write(address);
i2c_start();
i2c_write((0xa0|(byte)(address>>7))|1);
data=i2c_read(0);
i2c_stop();
return(data);
#separate
void write_pcf(byte address, byte data)
i2c_start();
i2c_write(0xa2);
i2c_write(address);
i2c_write(data);
i2c_stop();
#separate
byte read_pcf(byte address)
byte data;
i2c_start();
i2c_write(0xa2);
i2c_write(address);
i2c_start();
i2c_write(0xa3);
data = i2c_read(0);
i2c_stop();
return(data);
Thanks for help!
___________________________
Original Post ID: 4226 |
johnpcunningham Guest
| Re: I2C PIC16F876 PCF8583 24C16 - Problem |
Posted: Wed May 08, 2002 9:51 am |
Do you have pull-ups on the SDA and SCL lines? I wouls suggest something around 2.1K on each from my I2C experiences. I2C is sensitive to rise and fall times on some devices so the "hotter" pullup workes better.
Original Post ID: 4235 |
Posted: Wed May 08, 2002 3:00 pm |
<font face="Courier New" size=-1>:=I got wrong data when using read_pcf(4) (hours).
:=reading seconds ,days etc works fine!
:=Writing hours works, too.
Give us some examples of the failure.
ie., if you write 00, or 10, or 23, what do you read back ?
etc.
Note: The above numbers are intended to be in BCD format,
so you would actually write 0x00, 0x10, and 0x23 to
the hours register.</font>
Original Post ID: 4249 |
H. Schleyer Guest
Posted: Tue May 14, 2002 12:57 am |
writing the time works. Reading is fine as long the hour is not changing. Then Hours are 00. (BCD, of course).
when I pull the 24C16 of socket, time reading is fine.
So I think it's something with addressing.
:=<font face="Courier New" size=-1>:=I got wrong data when using read_pcf(4) (hours).
:=:=reading seconds ,days etc works fine!
:=:=Writing hours works, too.
:=Give us some examples of the failure.
:=ie., if you write 00, or 10, or 23, what do you read back ?
:= etc.
:=Note: The above numbers are intended to be in BCD format,
:= so you would actually write 0x00, 0x10, and 0x23 to
:= the hours register.</font>
Original Post ID: 4337 |
H. Schleyer Guest
Posted: Tue May 14, 2002 1:00 am |
sure. tried 1k and 10k. same effect.
:=Do you have pull-ups on the SDA and SCL lines? I wouls suggest something around 2.1K on each from my I2C experiences. I2C is sensitive to rise and fall times on some devices so the "hotter" pullup workes better.
Original Post ID: 4338 |
Posted: Fri Jan 06, 2006 9:02 am |
| Give me an example how to write minutes and hours into 8583. |
