Printing from Pc serial port to parallel port printer
oyhan
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun Nov 30, 2008 7:50 am     Reply with quote
Hi
I want to write some character from pc serial port to parallel printer. Mini Thermal Printer has 24 colon and parallel port.
While printer is writing I saw some problem. Printer is not write some data specially after 48th character.
I use hardware flow control that is rs232 DSR pin. While printer buffer is full I want to stop Pc data transmit after printer buffer is emptied.
What is my problem ? Would you help me please for that.
Best Regards...
#include <18F452.h>
//#device adc=10
#fuses HS, NOWDT, NOPROTECT, NOCPD, NOBROWNOUT, NOWRTD, PUT, NOLVP
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, bits=8, ERRORS)
#byte    PORTA  = 0x0F80
#byte    PORTB  = 0x0F81
#byte    PORTC  = 0x0F82
#byte    PORTD  = 0x0F83
#byte    PORTE  = 0x0F84
#bit     STROBE = PORTA.0  //for paralelle port printer busy_pin output
#bit     BUSY   = PORTA.1  //for paralelle port printer busy_pin input
#bit     DSR    = PORTC.2  //for rs232 hardware flow control
#byte RCREG = 0x0FAE
#byte RCSTA = 0x0FAB
#bit RCIF = RCREG.5
#bit OERR = RCSTA.1
#bit CREN = RCSTA.4
#define LF ('\n')
#define CR (0xD)
char b;
int1  rcvd_uart = 0;
#int_RDA
void  RDA_isr(void)
   DSR=1;  // Data Set Ready is passive
   b=RCREG;
   rcvd_uart = 1;
{  setup_adc_ports(NO_ANALOGS); setup_adc(ADC_OFF);
   setup_spi(FALSE);   setup_psp(PSP_DISABLED);  setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_OFF); setup_oscillator(False);
   setup_timer_1(T1_DISABLED);
   SET_TRIS_A( 0b10000010 ); SET_TRIS_D( 0x00 ); SET_TRIS_C( 0b10001011 ); SET_TRIS_E( 0b11111 );
   PORTD=0x00;
   STROBE=1;
   DSR=0;  // Data Set Ready is active
   putc(LF); putc(CR);
   Delay_Ms(1000);
   enable_interrupts(INT_RDA);
while(true)
      if(rcvd_uart)
      {  rcvd_uart = 0;
         PORTD = b ;
         while (BUSY);
         STROBE=0;
         delay_us(1);
         STROBE=1;
FvM
PostPosted: Sun Nov 30, 2008 10:28 am     Reply with quote
With PC RS232 hardware handshake, CTS rather than DSR is the signal to be used to signal peripheral busy/ready state.
oyhan
PostPosted: Sun Nov 30, 2008 3:47 pm     Reply with quote
Hi again..
I checked CTS RTS signal but they are same. No difference.
My code lose some characters. What is my code problem?
PostPosted: Sun Nov 30, 2008 3:56 pm     Reply with quote
Post the manufacturer and part number of your printer.
oyhan
PostPosted: Sun Nov 30, 2008 4:14 pm     Reply with quote
For example If I Send some characters with a file from pc lpt1 port I do not see any problem.
"c:\>copy lpt1 test.txt" this printer is write easily and true.
My printer information:
CARD STAR
Thermodrucker
Artikel-Nr.:0810
celectronic
PostPosted: Sun Nov 30, 2008 4:23 pm     Reply with quote
Post a link to the webpage that has a data sheet or manual for the printer.
oyhan
PostPosted: Mon Dec 01, 2008 3:24 pm     Reply with quote
How can I do that? For my problem..
PostPosted: Mon Dec 01, 2008 3:40 pm     Reply with quote
I'd suggest you try 'early stopping'.
CTS usually affects the daa being loaded to the transmission, rather than the UART directly. If you are running with a normal modern UART, a few characters actually 'in transmission', can still be sent after you say it is not 'clear to send'.
So, use an interrupt driven serial buffer, like EX_SISR. Have this using a buffer of (say) 64 characters, and signal it is not clear to send, when this gets to perhaps 3/4 full (48 characters). Only re-enable the comms, when the buffer empties.
This is the 'normal' strategy used in such handling, and should avoid loss of characters.
In your case, at the least, the character in the outgoing shift register, and possibly a couple in the incoming shift register and latch, could all arrive after the line activates. Possibly more.
