TMR1H doesn't increment!
BlueTower
PostPosted: Sun Nov 30, 2008 3:01 pm     Reply with quote
I am using PIC18F65J90 and in my code I have:
TMR1L = 0x00; // Used for 2 seond clock for RTC
TMR1H = 0x00; // External 32.768KHz crystal
T1CON = 0x4F;
while(!(TMR1H & 0x10)); // Wait a while for Timer 1 to start
// This is necessary due to bug in processor
// That can cause LCD not to start correctly
// if the timer isnt fully up and running
When pc goes in while condition TMR1L increments since I am using a clock stimulus. When TMR1L overflows there is no increment in TMR1H seen in Watch window. Am I missing something here?
PostPosted: Sun Nov 30, 2008 3:10 pm     Reply with quote
Go to the Timer1 section of the data sheet and read this section:
Timer1 16-Bit Read/Write Mode
PostPosted: Sun Nov 30, 2008 3:11 pm     Reply with quote
Haven't checked the data sheet for this chip, but it sounds like the 8/16 bit access behaviour. Basically if 16bit access is enabled, TMR1H, will _only_ update, when TMR1L is read. This is done to ensure that both accesses take place in one clock cycle. The debugger probably does not actually trigger the chip to perform a read.
BlueTower
PostPosted: Mon Dec 01, 2008 6:08 am     Reply with quote
Thanks my friend. The best way to do it in order debugging to work as well for Timer1 & Timer3 is enable 8 bit read/write and use the get_timer1(), get_timer3() function. This way all 16 bits will be updated!!!
