desert Guest
16F877A dual PWM signals problem |
Posted: Fri Nov 28, 2008 10:12 am |
hi all,
I try to generate 2 PWM signals at CCP1 & CCP2 via this simple code:
#include <16F877.h>
#use delay(clock = 4000000)
output_low(PIN_C1); // Set CCP2 output low
output_low(PIN_C2); // Set CCP1 output low
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_ccp2(CCP_PWM); // Configure CCP2 as a PWM
setup_timer_2(T2_DIV_BY_4, 124, 1); // 500 Hz
set_pwm1_duty(62); // 25% duty cycle on pin C2
set_pwm2_duty(62); // 50% duty cycle on pin C1
while(1); // Prevent PIC from going to sleep (Important !)
Checking with a scope I get the PWM I want at CCP2 but no luck on CCP1 no matter what I do.
Could this be due to a faulty PIC?
Is there a way to rule out this option?
Thanks for the help,
Moshe |
Posted: Fri Nov 28, 2008 11:47 am |
Are there any external components connected to the CCP1 pin (Pin C2) ? |
desert Guest
Posted: Fri Nov 28, 2008 3:36 pm |
No, I disconnected everything so I can examine the micro controller alone.
it was originally connected to an H BRIDGE, but once it failed I started investigating.
the whole thing is mounted on a breadboard, but I sample the signal at the chip leg directly.
I find the chances of a hardware malfunction slim, but who knows...
any guesses or suggestions will be welcome.
thanks,
Moshe. |
Posted: Fri Nov 28, 2008 3:49 pm |
Quote: | it was originally connected to an H BRIDGE, but once it failed |
Try a new PIC. |
desert Guest
Posted: Fri Nov 28, 2008 4:10 pm |
thanks for the help, I will try... |
mlkushan
Sample code to generate two 40KHz PWM signals |
Posted: Tue Dec 02, 2008 12:20 am |
Check this code segment. This works fine. Hope this will be helpful to you also. This generates 40KHz PWM signals on both PIN_C1 and PIN_C2.
Thanks.
#include <16F877A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
int16 pwm_duty = 50; //to get a higher resolution
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,24,1);
set_pwm1_duty(pwm_duty);
set_pwm2_duty(pwm_duty);
setup_vref(FALSE);
// TODO: USER CODE!!
_________________ Kushan Sharma
mlkushan@gmail.com |
