18F2520 pin B0 not responding???
Franck26
PostPosted: Fri Nov 28, 2008 7:47 am     Reply with quote
Hello every body,
I've got a weird issue with the portB pin 0 of the 18F2520.
I cannot have a low level on this pin.
This pin is connected to a 4.7k pull-up and I've check for short.
the code is very simple:
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
      #asm
         nop
         nop
      #endasm
      output_low(PIN_B0);
      #asm
         nop
         nop
      #endasm
Registers after execution (debugging with ICD-U40):
TRISB = 0xFE,
LATB = 0xFE,
PORTB = 0x1F ???
Why does the PORTB register keep b0 set?
Is there a special function for this pin that I haven't seen in the datasheet?
Thanks for any help.
Franck.
PCD 4.083.
Franck26
PostPosted: Fri Nov 28, 2008 9:04 am     Reply with quote
I think I found the problem: pin B0 dead on both 18F2520 that I was tested...
Stupid mistake Embarassed ,sorry about that.
Franck.
Wayne_
PostPosted: Fri Nov 28, 2008 9:11 am     Reply with quote
Sure your not using #use fast_io
As you have left out the #use statements from your listing we cannot tell.
Franck26
PostPosted: Fri Nov 28, 2008 9:34 am     Reply with quote
I was not using the fast io, I checked the asm code to be sure.
I have changed the micro and it's working now.
Thanks,
Franck.
