why compiler always stop in #device ADC=10
Monk9514524
PostPosted: Thu Nov 27, 2008 9:06 am     Reply with quote
hello guys
I have a problem that my program doesn't compile.
Always stop in the #device ADC=10
and the complier show me the error "Can not change this device into this code". What happen?
Did anybody have run into this ?
asmboy
the usual drill
PostPosted: Thu Nov 27, 2008 9:15 am     Reply with quote
post enough info for it to be figured out.
FACTS needed
1- what pic ?
2- your compiler version
3- enough of your source code that shows all this
starting from you top of file includes
then a good answer can be given
but a first guess is that you are programming a pic with only 8 bit A/D hardware.
PostPosted: Thu Nov 27, 2008 10:08 am     Reply with quote
The error message is what you will get, if you include almost anything except the processor definition file and fuses before this line.
Order:
Processor definition file
Fuse declarations
Device settings
Clock settings
RS232, SPI etc. setups.
Only then start including the library files
Then the main code
Obviously, lines 2,3,4,5, can themselves be combined into a single include file, but the order must basically remain the same.
asmboy
here is an EASY thing to test
PostPosted: Thu Nov 27, 2008 12:08 pm     Reply with quote
you can also try this :
1- find the .H file for your pic
the first executable line should look like this
#DEVICE=16F886
2- edit it to be:
#DEVICE=16F886 ADC=10
3- then remove the isolated #DEVICE ADC=10 from your main prog file
AND compile again
otherwise - submit more info
PostPosted: Thu Nov 27, 2008 12:59 pm     Reply with quote
You don't have to edit the .H file. See the sample code in this thread
which shows how to use the A/D:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168
