Interrupt Priority
esakki
Interrupt Priority
PostPosted: Tue Nov 25, 2008 2:12 am     Reply with quote
In CCS how to assign interrupt priority for a function? Thanks in advance for your help.
Rohit de Sa
PostPosted: Tue Nov 25, 2008 2:49 am     Reply with quote
Interrupt priority level is set by hardware. It depends if your PIC is capable of having multiple priority levels; this is possible on the 18 series and higher PICs.
Have a look at the Interrupts section in the CCS manual, particularly the directive #device high_ints .
Read Ttelmah's post:
http://ccsinfo.com/forum/viewtopic.php?t=36497&highlight=priority
http://ccsinfo.com/forum/viewtopic.php?t=36218&highlight=priority
Rohit
PostPosted: Tue Nov 25, 2008 3:13 am     Reply with quote
There are two sorts of interrupt 'priority'.
The hardware form, is only available on the 18 or latter chips, and is what Rohit is referring to.
Separately, there is a 'software' form, which adjusts the _order_ in which the interrupt flags are checked in the handlers. This is set by two things. First, the order that the interrupts are declared. Basically if you declare an interrupt first in the code, it will be checked before other interrupt handlers declared latter. Alternatively, you can use the #priority declaration, which allows you to specify this 'checking' order.
So you can actually set the order with which interrupts are scanned, inside each of the two hardware levels, by using combinations of these.
esakki
Intterupt Priority
PostPosted: Wed Nov 26, 2008 10:34 pm     Reply with quote
Thanks for your reply. i wil do with this reference. thanks lot you all.
