software SPI?
bignick270
software SPI?
PostPosted: Wed Nov 26, 2008 8:00 am     Reply with quote
Is there a way to set up a software SPI connection or would I have to do it by hand?
PostPosted: Wed Nov 26, 2008 8:46 am     Reply with quote
Depends on your compiler version.
With a 'V3' compiler, you need to go DIY. However there is code for several SPI devices driven using software, in the drivers directory, and you can probably 'borrow' what is needed from this.
With a V4 compiler, the #USE SPI setup, exists, and this supports both software and hardware SPI, using a stream name, and the spi_xfer call to do the I/O.
