r2d2 Guest
kbhit() does not hit at all |
Posted: Mon Nov 24, 2008 11:29 am |
Hi Forum,
I am trying to catch an user input over RS232 with kbhit().
Down below you can see the whole program.
My problem is, that kbhit() does not hit any time and so the if-statement (marked with ***** 1 *****) is never executed.
I tryed several work-arounds and I also viewed the RS232-Input by putting out every char with putc().
Everything works fine, but no kbhit() will occour at all.
Please give me some help
Dirk
(Excuse, that the Code has no tabs, I didn't know how to get the code out of CCSC with tabs)
Code: | #opt 0
#include <18F252.h>
#fuses HS,WDT,WDT128,PUT,BROWNOUT,BORV45,PROTECT,NOLVP
#FUSES WRTB //Boot block write protected
#FUSES CPB //Boot Block Code Protected
#use delay(clock = 40M, oscillator = 10M, restart_wdt)
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7,restart_wdt) //
#define _bootloader
#include <bootloader.h>
#include <loader.c>
#rom 0xf000ff={255} // Flag for bootloader start
#org LOADER_END+2,LOADER_END+20
void application(void) {
while(TRUE);
#org 0x20,0xFF
void main(void) {
byte eeprom_value, i;
eeprom_value = read_eeprom(0xf000ff);
if(eeprom_value>=127){ // 255: programming default value
load_program(); // 127: value after successful bootloader Menue
write_eeprom(0xf000ff,0);
else {
for (i=0;i<250;i++) { // test 250 times, if an event occurs on RS232
if (kbhit()){ // ****** 1*****
if(getc() == 0x1B) { // this case will hit, if [ESC] is pressed and hold during power on
load_program(); // start bootloader from RS232
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END +10);
ECACE
Posted: Mon Nov 24, 2008 12:36 pm |
For starters, strip out all the bootloader stuff. Start with just the code that is giving you the problem and get it to work before adding the loader.
Second, what version of the compiler are you using?
With that information given, we can help out. As it stands now, are you sure it isn't a loader problem or your values in the eeprom? Let's narrow it down first, so get rid of everything but the kbhit problem.
Best of luck. _________________ A HW Engineer 'trying' to do SW !!! Run!!! |
Posted: Mon Nov 24, 2008 1:40 pm |
Code: | #use delay(clock = 40M, oscillator = 10M, restart_wdt) | From this line it looks like you are using a 10MHz crystal + 4xPLL to reach 40MHz.
The above setup might work on some of the newer chips with software controllable clock configuration but not on the good old 18F252 where you have to enable the PLL by setting a fuse. Change the HS fuse to H4 (HS + 4xPLL).
Code: | write_eeprom(0xf000ff,0); | The address value is too large. The write_eeprom 'knows' the base address so you only have to specify the actual offset (0xFF).
Like ECACE suggested, bug hunting is easier when you simplify your program by removing all not required stuff. |
Posted: Mon Nov 24, 2008 5:28 pm |
Hi ECACE and ckielstra,
Thanks for your help first.
I did not know the things you wrote about oscillator settings and eeprom-address range. At first I changed the settings, but that was not the solution for my bug.
Then I simplified the program and installed an Answer over RS232 every time the pic gets the kbhit(). The Answer('A') did not come.
(I tested this also before my first post). Then I throw away the loader.c-file and my bug was fixed. What is there going on in the loader.c-file, that collides with my program?
Here is the actual Code
Thanks for more Help.
Dirk
Code: | #opt 0
#include <18F252.h>
#fuses H4,WDT,WDT128,PUT,BROWNOUT,BORV45,PROTECT,NOLVP
#define _bootloader
//#include <loader.c> //***** if I uncomment this line kbhit() does not work any more
while(TRUE);
#org 0x20,0xFF
void main(void) {
eeprom_value = read_eeprom(0xff);
//if(eeprom_value>=127){ // 255: programming default value
//load_program(); // 127: value after successful bootloader Menue
// write_eeprom(0xff,0);
//else {
if (kbhit()){
//load_program(); // start bootloader from RS232
//write_eeprom(0xff,255);
//break;
putc('A');
i--;
//application();
#ORG default
#int_global
void isr(void) {
Posted: Wed Nov 26, 2008 5:29 pm |
There are no big differences between your bootloader and the ex_bootloader.c program so at a quick glance I don't see what is causing your problems.
One suggestion is to add the 'errors' keyword to the '#use rs232' line. The hardware UART will stop receiving when the input buffer overflows, that is after 3 characters, and only starts receiving again after explicit error reset. Adding the errors keyword causes the compiler to add code for resetting the error condition on every getc call.
For further looking into your problem you need to post your compiler's version number. |
