a.fava
Joined: 25 Jun 2004 Posts: 17 Location: Cremona (Italy)
| pwm code on PIC24 |
Posted: Mon Nov 17, 2008 1:47 pm |
Hello
Ineed to use the output pin OC1 -2 -3 in PWM mode of the micro PIC24FJ128GA010.
I tried several times as shown in the code list, but it didn't work.
My compiler is PCWHD version 4.081.
Anyone can help me ?
Thanks.
Alessandro
| Code: | #include <24FJ128GA010.h>
#FUSES NOJTAG //JTAG disabled
#FUSES NOCOE //Device will reset into operational mode
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES HS //High speed Osc (> 4mhz)
#FUSES FRC //Internal Fast RC Oscillator
#use delay(clock=8000000)
setup_adc_ports(sAN5);
setup_adc(adc_clock_internal);
set_adc_channel(5);
setup_compare(1,COMPARE_PWM | COMPARE_TIMER3 );
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_1,0 );
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
enable_interrupts(INT_TIMER3);
int value;
int pw_val;
value=read_adc();
pw_val = value * 64;
set_pwm_duty(1, pw_val);
_________________ Alessandro |
FvM
Posted: Mon Nov 17, 2008 4:13 pm |
| I think, you should preset the timer to 0xFFFF rather than 0 to see any PWM action. Also I don't see the purpose of enabling timer interrupt without defining a handler, but fortunately global interrupts are still disabled. |
a.fava
| pwm code |
Posted: Tue Nov 18, 2008 2:16 pm |
Thank you FvM
I tried to load the timer 3 with 0xFFFF and I didn't use the timer3 interrupt as I think it's not necessary.
But it doesn't work.
Have you got any idea ?
Alessandro _________________ Alessandro |
nicotec
| pwm |
Posted: Wed Nov 19, 2008 5:15 am |
I have similar problem with pic24fj16ga002 using this code:
#pin_select OC1=PIN_B4
setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1);
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
//set_pwm_duty(1,30000);
output_low(PIN_B8);
do
output_high(PIN_B6);
output_low(PIN_B6);
} while(true);
How do You think to solve the problem? |
a.fava
Posted: Wed Nov 19, 2008 1:07 pm |
I thank you NICOTEC for the answer.
But the problem is that the function #pin_select...... the CIP 24FJ128GA010 there is and does not work.
For other types of microcontrollers the function #pin_select.... works and I have no problem of programming or operation. _________________ Alessandro |
