Posted: Tue Nov 18, 2008 2:58 pm |
Hi ! I'm newcomer . May I have a question ?
My problem is "PWM resolutions".I don't know about it .
Would you please help me ?
Thanks very much! |
dientudong
Posted: Wed Nov 19, 2008 2:49 am |
Code: | #include "E:\BAIBAOCAONHOM7\New Folder\taolao.c.h"
#include<16F877A.h>
unsigned char num[8]={0x00,0x15,0x21,0x31,0x48,0x50,0x64,0x78};
unsigned char j ;
set_tris_c(0);
for(j=0;j<8;j++)
PORTC=num[j];
delay_ms(1);
My problem is "error in PORTC". Would you please help me ?
Split thread into new topic.
-- Forum Moderator. |
Posted: Wed Nov 19, 2008 5:24 am |
There is nothing called 'PORTC', unless you have declared it...
If you want to write a value to the port, the CCS function, is output_c(num[j]);
This has _nothing_ to do with PWM, which this thread is about.Why post your question here?... |
dientudong
Posted: Wed Nov 19, 2008 8:20 am |
Code: | #include <16F877A.h> //
#use delay(clock=20000000) //
#include <lcd.c> //
float vantoc,soxung; //
int8 a,b,c,d,a1; //
int16 sovong,i; //
////////////khai bao va chuong trinh ngat cho TIMER1/////////////////////
#int_TIMER1 //
void TIMER1_isr(void) //
soxung=get_timer0(); //get num pulses thatTimer0 counts //
set_timer1(65535); // Trong 1ms //
if(tmr1if==1) //if Timer1 overflows , tmr1if =1 //
intcon=0; //stop ngat (reset interrupt parameters ) //
a1=1; //cho a1=1 //
//////////////////////////end TIMER1///////////////////////////
//////////////////////////begin main program////////////////////////////
trisa=0xFF; //set RA4 input,pin get pulses from Encoder
trisb=0; //portC is output
trisc=0; // portC is output
trisd=0; // portD is output
lcd_init(); //ham khoi tao LCD
lcd_gotoxy(1,1); //row 1 column 1
lcd_putc("Beginning...."); // print beginning....
delay_ms(1000); // 1s
lcd_putc('\f'); //dotpoint flashs
setup_timer_2(T2_DIV_BY_2,254,1); //tao f(pwm)=9775Hz or T(pwm)=0.1023ms
setup_ccp1(CCP_PWM); //thiet lap chan CCP1 o che do PWM
for(i=0;i<1000;i++) //tu 0 den 1000 thi toc do tang dan
set_pwm1_duty(i); // Toc do tang dan
delay_ms(1);
set_timer0(0); //lam moi Timer0 de chuan bi dem xung
set_timer1(65535); //dat gia tri cho Timer1_khoang 1s
setup_timer_0(RTCC_EXT_H_TO_L|RTCC_DIV_1);
enable_interrupts(INT_TIMER1); //cho phep ngat Timer1
enable_interrupts(GLOBAL); //cho phep ngat toan cuc
delay_ms(10); //
if(a1==1) //every Timer1 interrupts, a1=1 ,then calculate vantoc
vantoc=((float)(60*soxung)/(0.01*100)); //Tinh van toc
a=vantoc/1000; //chia lay phan nguyen
b=(int)(vantoc-1000*a)/100; //chia lay phan nguyen
c=(int)(vantoc-1000*a-100*b)/10; //chia lay phan nguyen
d=(int)vantoc%10; //chia lay phan du
///////////////////toi phan hien thi LCD/////////////////////////////
lcd_gotoxy(3,3); //den vi tri hang 3 cot 3
lcd_putc(a+48); //in ra a
lcd_gotoxy(3,4); //den vi tri hang 3 cot 4
lcd_putc(b+48); //in ra b
lcd_gotoxy(3,5); //den vi tri hang 3 cot 5
lcd_putc(c+48); //in ra c
lcd_gotoxy(3,6); //den vi tri hang 3 cot 6
lcd_putc(d+48); //in ra d
lcd_gotoxy(4,3); //den vi tri hang 4 cot 3
lcd_putc("vong/phut"); //in ra "vong/phut"
lcd_gotoxy(2,2); //den vi tri hang 2 cot 2
lcd_putc("toc do dc"); //in ra "toc do dc"
delay_ms(5); //
tmr0if=0;tmr1if=0; //Xoa co tran cua Timer0 va Timer1
I have problem in the code. Please help me. |
