		| Author | Message |
		| M0KHZ
				| 48 bit data type |
				|  Posted: Mon Nov 17, 2008 11:45 am |   |
				| I’m thinking about starting an application that requires a 48 bit word to be calculated (FTW), the calc is straight forward,
 FTW = (2 raised to the power of 48 * (DDS_out/DDS_Clock)).
 Is this feasible to do with PCH compiler and a PIC18Fxxx, or should I
 jump in and purchase the PCD compiler and use a PIC24xxx,
 as type int48 data type is available?
 Suggestions welcome.
 Kevin – M0KHZ
		| SherpaDoug
				|  Posted: Mon Nov 17, 2008 1:26 pm |   |
				| If that one function is all you need the 48 bit type for, I would create a 48 bit structure and write 8 bit functions to manipulate it.  It looks like PCD still has problems of its own, and I would not use it for a paying job unless I really needed to. _________________
 The search for better is endless.  Instead simply find very good and get the job done.
		| Ttelmah Guest
				|  Posted: Mon Nov 17, 2008 2:24 pm |   |
				| A while ago, I did post some basic 48bit arithmetic routines. A search should find them.
		| M0KHZ
				|  Posted: Mon Nov 17, 2008 3:15 pm |   |
				| Thanks guys, you've given me loads to sleep on, I don't think a new compiler is the answer here
 Kevin - M0KHZ
