does ccs support double precision floating point number?
vty0207
PostPosted: Mon Nov 17, 2008 3:04 am     Reply with quote
does ccs support double precision (64 bit) floating point number ?
I need 8-9 significant digit after the floating point. Eg. 3.141592654.
PICoHolic
PostPosted: Mon Nov 17, 2008 3:50 am     Reply with quote
The manual says:
double is a reserved word but is not a supported data type.
But if write down:
double p = 3.1415123;
it compiles under 4.082
mmm....
PostPosted: Mon Nov 17, 2008 4:02 am     Reply with quote
Double is just treated as an alias for float. So it'll compile, but not give you any extra accuracy, _unless_ you are using PCD. On these chips, double is supported.
If you look in the maths include file, you will find a whole suite of 'overloads' for the 64bit functions, that only only apply if your compiler is PCD.
vty0207
PostPosted: Mon Nov 17, 2008 7:18 pm     Reply with quote
What is PCD ? Is there another solution that I can process and calculate double precision (64 bit) floating point number ? Is switching to another compiler a solution ?
PostPosted: Mon Nov 17, 2008 11:49 pm     Reply with quote
Yes, PCD is supporting double according to the manual. But I didn't yet use it.
