VAR 32 in lib linear_24LC512
Orcino
PostPosted: Thu Nov 13, 2008 12:08 pm     Reply with quote
in code linear_24lc512 listed below, how write a var 32 bits ?
Thanks.
Orcino
////        Library for lineal address to a bank of 8 24LC512 chip memory      ////
////        0 to 0x07FFF                                                       ////
//// init_24512x8();  Call before the other functions are used                 ////
//// writeByte24512x8(a,d); Write the byte (int8)d to the address (int32)a     ////
//// d=ReadByte24512x8(a); Read the byte int8)d from the address (int32)a      ////
//#ifndef EEPROM_SDA
//#define EEPROM_SDA  PIN_B0
//#define EEPROM_SCL  PIN_B1
//#endif
//#use i2c(master,slow,sda=PIN_B0,scl=PIN_B1,force_hw)
#define MULTIPLE_EEPROM_ADDRESS int32
#define EEPROM_SIZE  524288
void init_ext_eeprom()
   output_float(PIN_B0);
   output_float(PIN_B1);
void writeByte_24512x8(int32 memaddress, int8 data){
   int16 address;
   int8  controlbyte;
   short int status;
   address=memaddress;
   controlbyte=(0xa0 | ((make8(memaddress,2))<<1));
   i2c_start();
   i2c_write(controlbyte);
   i2c_write(address>>8);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
   // AckNolege pooling
   i2c_start();
   status=i2c_write(controlbyte);
   while(status==1)
     i2c_start();
   i2c_stop();
int8 readByte_24512x8(int32 memaddress){
    int16 address;
    int8  controlbyte;
    int8  data;
    address=memaddress;
    i2c_start();
    i2c_write(address);
    i2c_start();
    i2c_write(controlbyte|1);
    data=i2c_read(0);
    i2c_stop();
    return data;
PostPosted: Thu Nov 13, 2008 12:14 pm     Reply with quote
See the CCS FAQ:
http://www.ccsinfo.com/faq.php
See this article:
How do I write variables to EEPROM that are not a byte?
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
