Connecting a PIC with an Ezurio Bluetooth module help
justrain
PostPosted: Wed Nov 12, 2008 4:01 pm     Reply with quote
Hi, i'm trying to connect a PIC18F4680 module to a Bluetooth BISM from Ezurio (BISMS02BI) which uses the AT command language for configuration. I'm connecting both parts with an RS232 connection but the problem is that whenever I send a comand i.e ATZ followed by the 0x0D I get no response from the Bluetooth module, i've connected the PIC to a PC terminal and checked that the commands were sent right, but when I replace the PC with the bluetooth I get nothing.
Does anyone have some idea what this is happening? bellow is the code I'm using which is on assembly...
org 0x860
msjez: DB "ATZ."
org 0x880
msje: DB "ATE0."
org 0x900
msjep: DB "AT+BTW111111111111."
;msje_2:DB "AT+BTK='0000'."
org 0x990
Main:
;Serial PORT Config
movlw 0x24
movwf TXSTA
movlw D'25'
movwf SPBRG
bsf TRISC, 7 ; rc6   =TX
bcf TRISC, 6 ; rc7  = RX
bsf RCSTA, 7
; LCD CONFIG
 clrf PORTD
 movlw 0x00
 movwf TRISD   ;puerto D como salida
  bsf TRISC, 3  ; SW 7
  bsf PORTC, 3
  bcf TRISA, 1
  bcf TRISA, 2
  bcf TRISA, 3
  bcf PORTA, 1
  bcf PORTA, 2
  bcf PORTA, 3
  movwf ADCON1
  movlw 0x0F
 bsf PORTA,3    ; EN = 1
 bcf PORTA,1    ; RS = 0
 movlw 0x38    ; 8-bit interface, character de 5x8
 movwf PORTD
 bcf PORTA,3    ; EN = 0
 call delay
 call reload_lcd
;;;;;;; SEND MESSAGES TO THE Bluetooth module
movlw 0x08
movwf TBLPTRH
movlw 0x60
movwf TBLPTRL
clrf  TBLPTRU
call send_message
movlw 0x0D
call putc_usart
call write_lcd
call read_response
movlw 0x08
movwf TBLPTRH
movlw 0x80
movwf TBLPTRL
clrf  TBLPTRU
call send_message
movlw 0x0D
call putc_usart
call write_lcd
call read_response
movlw 0x09
movwf TBLPTRH
movlw 0x00
movwf TBLPTRL
clrf  TBLPTRU
call send_message
movlw 0x0D
call putc_usart
call write_lcd
call read_response
loop2 goto loop2
loop
call delay500
bsf PORTC, 0
goto loop
delay500
       movlw 0x07
      movwf 0x54
m3delay
       movlw 0xFF
      movwf 0x53
m2delay decfsz 0x53,1
       goto m2delay
       decfsz 0x54,1
       goto m3delay
return
; read the response sent
read_response
movlw 0x61
movwf 0x0A
    ciclin:
        call getc_usart
        cpfseq 0xA0
        goto finciclin
        goto fincicle
    finciclin:
        call write_lcd
        goto ciclin
    fincicle:
return
; send a character through USART
putc_usart
btfss PIR1, 4  ; checks that the flag is set = data ready
bra putc_usart
movwf TXREG
return
; recieve character through USART
getc_usart
btfss PIR1, 5  ; checks that the flag is set = data ready
bra getc_usart
movf RCREG, 0
return
;Send a compossed message
send_message
looop
tblrd*+
movlw 0x2E
movwf 0x0C
movf TABLAT, 0
cpfseq 0x0C
goto g
goto g2
g
call putc_usart
call write_lcd
goto looop
g2
return
;LCD subroutines
write_lcd
   bsf PORTA,1 ; RS = 1
   movwf PORTD
   call delay  ;grande
return
delay  movlw 0xFF
      movwf 0x53
mdelay decfsz 0x53,1
       goto mdelay
return
;Restart LCD
reload_lcd
;LCD ON - CURSOR OFF
 movlw 0x0F ; LCD ON, Cursor ON
 movwf PORTD
 call delay
;CURSOR @ Home
 movlw 0x02    ; cursor at home
 movwf PORTD
 call delay500    ;delay500
;Clear
 movlw 0x01      ; Clear screen
 movwf PORTD
 call delay500
return
;End of program
      END
justrain
PostPosted: Wed Nov 12, 2008 4:08 pm     Reply with quote
Sorry got something wrong on the routine that reads the response:
read_response
movlw 0x0D
movwf 0x0A
    ciclin:
        call getc_usart
        cpfseq 0x0A
        goto finciclin
        goto fincicle
    finciclin:
        call write_lcd
        goto ciclin
    fincicle:
return
Basically it waits until it receives an enter (0x0D) and then gets out.
PostPosted: Wed Nov 12, 2008 4:59 pm     Reply with quote
This is not an ASM board. It's a CCS C board. Re-write your code in C.
