Problem getting Timer 1 to work....
PostPosted: Wed Nov 12, 2008 1:47 pm     Reply with quote
Hi All,
I'm having trouble getting Timer1 to run. I think I'm setting it up correctly according to my Version 4.0 manual (August 2006), but the Get_Timer1 statement always returns a 0 :-(!
Here is a short piece of code that demonstrates the problem:
#include <12F629.h>
#fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPROTECT,MCLR
#define LCD_Output          Pin_A0
#use rs232(baud=9600, xmit=LCD_Output)
   int16 PulseWidth;
   printf("Hello World \n\r");
      setup_timer_1 ( T1_INTERNAL|RTCC_DIV_256 );
     set_timer1(0);
      PulseWidth = get_timer1();
      printf("Counter value: %2X\n\r", PulseWidth);
  }   //while
} //main
I'm continuously polling Timer1, and sending the data to a PC. I'm expecting that the small delay associated with the printf function will show me a different value for Timer1 each time, but it's always zero!
My compiler version is 4.050
Thanks,
Doug
PostPosted: Wed Nov 12, 2008 3:47 pm     Reply with quote
int16 PulseWidth;
setup_timer_1 ( T1_INTERNAL | RTCC_DIV_256 );
set_timer1(0);
} //while
Look closely at the line in bold. There is a problem on that line. Look at
the 12F629.H file, in the sections on the timers. Hint: What is the name of
each timer ?
PostPosted: Wed Nov 12, 2008 4:04 pm     Reply with quote
PCM,
Yep, I already found that :-(! The problem is that I was trying to re-use some old Timer0 code, and didn't check it closely enough! I changed the line to:
setup_timer_1 ( T1_INTERNAL|T1_DIV_BY_8 );
and everything is happy now!
Doug
