Need help with PIC16F877 4-digit seven segment power meter
marabdul
PostPosted: Sun Nov 09, 2008 3:14 am     Reply with quote
I am trying to design digital power meter using PIC16F877 and CCS C compiler but I need somebody to guide me on how to write the program code. What I do not understand is after reading the ports how do I use the values from the adc and use them in computations and the display in 4-digits 7-segment.
Please I need someone to teach me these.
necati
power lcd
PostPosted: Sun Nov 09, 2008 4:16 am     Reply with quote
#include <16f873.h>
#device ADC=10    //volt lcd 5/5/2008
#fuses  XT, NOPROTECT,PUT, NOWDT,BROWNOUT
#use    delay(clock=4000000)
#use    rs232(baud=9600, xmit=pin_c6, rcv=pin_c7)
#BYTE   PORT_A=0X05
#BYTE   PORT_B=0X06
#BYTE   PORT_C=0X07
int16   volt,volt0,volt1,wat1;
int16   v,v0,v1,gvmax,avmax;
float   data=0;
float   ka=200.0/1024,kv=50.0/1024;
void charge(void);
void aku(void);
void mesure(void);
/***entegreterbiyecisi@yahoo.com***/
int16 duty=0;
int8 sec=50,sn=0,mn=0;
 #int_timer0
 ms_10(){
 set_timer0(70);  //(255-60)*128*20=  256ms
 if(sec){
 sec--;}
 else{sec=50;
 sn++;if(sn==60) {mn++;sn=0;}
// LCD STUFF
#define LCD_RS      PIN_b6
#define LCD_EN      PIN_b5
#define LCD_D4      PIN_b4
#define LCD_D5      PIN_b3
#define LCD_D6      PIN_b2
#define LCD_D7      PIN_b1
#define FIRST_LINE  0x00
#define SECOND_LINE 0x40
#define CLEAR_DISP  0x01
#define CURS_ON     0x0e
#define CURS_OFF    0x0c
#use fast_io ( a )
#use fast_io ( b )
#use fast_io ( c )
// proto statements
void LCD_Init        ( void );
void LCD_SetPosition ( unsigned int cX );
void LCD_PutChar     ( unsigned int cX );
void LCD_PutCmd      ( unsigned int cX );
void LCD_PulseEnable ( void );
void LCD_SetData     ( unsigned int cX );
void main(void){
      setup_adc_ports(all_analog);
      setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
      setup_timer_2(T2_div_by_16,128,1); //freq=4000000/4*1*128=500hz
      setup_ccp1(ccp_pwm);
      set_pwm1_duty(0);
      enable_interrupts(int_timer0);
      enable_interrupts(global);
      SET_TRIS_A   (0b11111111);
      SET_TRIS_B   (0b10000001);
      SET_TRIS_C   (0b10000011);
      PORT_A=0;
      PORT_B=0;
      PORT_C=0;
      LCD_PutCmd(CLEAR_DISP);
      LCD_SetPosition (first_LINE+0);
      printf (LCD_PutChar, "POWER METER    " );
      LCD_SetPosition (second_LINE+0);
      printf (LCD_PutChar, "50volt 200amper" );
   while(1){
   if(sn>2){aku();sn=0;}
void aku(void){
   mesure();
   LCD_SetPosition(first_LINE+0);
   printf(LCD_PutChar,"AKU " );
   data = (float)v0*kv ;
   LCD_SetPosition(first_LINE+4);
   printf(lcd_putchar,"\%02.1fV  ",data);
   data = (float)v1*ka;
   LCD_SetPosition(first_LINE+11);
   printf(lcd_putchar,"\%02.1fA ",data);//aku volt
   printf("duty=%ld,volt=%ld\n\r",duty,avmax);
//////////////////////////////////////ruz akim
      LCD_SetPosition(second_LINE+0);
      printf(LCD_PutChar,"POW " );
      data =(float)(v0*kv)*(v1*ka);
      LCD_SetPosition(second_LINE+4);
      printf(lcd_putchar,"\%01.0fw ",data);
//////////////////////////////////////wat1
/***entegreterbiyecisi@yahoo.com***/ //lcd basla
void LCD_Init ( void ){
    LCD_SetData ( 0x00 );
    output_low ( LCD_RS );
    LCD_SetData ( 0x03 );   // init with specific nibbles to start 4-bit mode
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_SetData ( 0x02 );   // set 4-bit interface
    LCD_PulseEnable();      // send dual nibbles hereafter, MSN first
    LCD_PutCmd ( 0x2C );    // function set (all lines, 5x7 characters)
    LCD_PutCmd ( 0x0C );    // display ON, cursor off, no blink
    LCD_PutCmd ( 0x01 );    // clear display
    LCD_PutCmd ( 0x06 );    // entry mode set, increment
    // this subroutine works specifically for 4-bit Port A
    LCD_SetData ( swap ( cX ) | 0x08 );
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );
    LCD_PulseEnable();
    output_high ( LCD_RS );
    LCD_SetData ( swap ( cX ) );     // send high nibble
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );     // send low nibble
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    output_high ( LCD_EN );
    delay_us ( 100 );
    output_low ( LCD_EN );
    delay_ms ( 5 );
    output_bit ( LCD_D4, cX & 0x01 );
    output_bit ( LCD_D5, cX & 0x02 );
    output_bit ( LCD_D6, cX & 0x04 );
    output_bit ( LCD_D7, cX & 0x08 );
/***entegreterbiyecisi@yahoo.com***/ //lcd son
void mesure(void){
   set_adc_channel(0);//voltage
   delay_us(25);
   v0= read_adc();
   volt0= v0*kv;
   set_adc_channel(1);//current
   delay_us(25);
   v1= read_adc();
   volt1= v1*ka;
   wat1=volt0*volt1; //watt
PostPosted: Sun Nov 09, 2008 1:15 pm     Reply with quote
Your code is for a parallel-interface character LCD module. He wants
a 7-segment display. He didn't say whether it should be LCD or LED.
The LED type looks like the first image here:
http://en.wikipedia.org/wiki/Seven-segment_display
The LCD type looks like the alarm clock image here:
http://en.wikipedia.org/wiki/Liquid_crystal_display
