Uart problem
Juls
Uart problem
PostPosted: Fri Nov 07, 2008 2:30 pm     Reply with quote
I got no idea but my tx pin is going high at reset and wont do anything
   Fichier:Encoder.c
   Date: 7 FEV 2008
   Auteur: Julien Gingras
   Revision: 1.0
   Compilation:
            Compilateur: CCS
            Version:     3.5.0.92
            Librairies:
/*                 ***** LISTE DES INCLUDES *****                            */
#include "Flex_LCD420.c"      //LCD driver
#use delay(clock=4000000)      // Fixer la vitesse de l'horloge
#CASE               // Met le compilateur CASE SENSITIVE
                        // Permet d'utiliser delay_ms() et delay_us()
#FUSES HS, NOPROTECT, NOBROWNOUT, NOWDT, NOPUT, NODEBUG, NOLVP, NOWRTD, NOFCMEN, NOCPB,
#use rs232(BAUD=38400, PARITY=N, BITS=8, STOP=2)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
/*                **** LISTE DES CONSTANTES *****                           */
#define NEC_INPUT PIN_A2
//we can t use B6 and B7 because they are use by ICD2
/*            **** LISTE DES VARIABLES GLOBALES *****                       */
   int1 nReady = 0;
   int szAnswer[150];
   int nPos = 0;
/*               ***** LISTE DES PROTOTYPES *****                           */
void main(void);
void InitPic(void);
void interrupt_RDA();
void interrupt_timer1();
void CheckRom(char *szTx, int nNum);
/*               ***** PROGRAMME PRINCPAL *****                             */
   int k, j = 0;
   unsigned int16 i = 0;
   int nCurrent;
   unsigned int8 nAdr;
   unsigned int8 nCom;
   int1 szNEC[40];
   int szMesh[30];
   int nSeq = 1;
   setup_oscillator(OSC_4MHZ);
   InitPic();
   lcd_gotoxy(1,1);
//Test la radio mesh
   szMesh[0] = 0xA5;    //Sync
   szMesh[1] = 2;      //Lengh
   szMesh[2] = 0xb;   //Type Get REV
   szMesh[3] = nSeq;     //Seq
   szMesh[4] = 0;      //CheckSum
   CheckRom(szMesh, 4);
   nSeq ++;
   //get rev de la radio mesh
   for(k=0;k<5;k++)
      putc(szMesh[k]);
  printf(lcd_putc, "%s", "Alex y rock\nen sale");
   while(!nReady)
      delay_us(100);
   nReady = 0;
   printf(lcd_putc, "%02X %02X %02X %02X %02X", szAnswer[0],szAnswer[1],szAnswer[2],szAnswer[3],szAnswer[4]);
   szAnswer[11] = 0;
 //  printf(lcd_putc, "%s", &szAnswer[5]);
   while(TRUE)   //Main Loop
   {   do
         //Looping here we can check if we received something on the rs232 (an event)
         if(nReady)
            switch(szAnswer[2])
               case 4:
                  lcd_gotoxy(1,2);
                  printf(lcd_putc, "DATA IN %02X %02X", szAnswer[1], szAnswer[29]);
            nReady = 0;
         //Check the state of the remote input
         nCurrent = input_state(NEC_INPUT);
      }while(nCurrent);//Loop that wait a input
      i = get_timer0()*2;
      set_timer0(0);   //Reset the timer
      if((i>1100)&&(i<1300))
         szNEC[j] = 0;
         j++;
      else if((i>2200)&&(i<2600))
         szNEC[j] = 1;
         j++;
      else if((i<15000)&&(i>13000))
         j = 0;
      while(!input_state(NEC_INPUT));
      if(j == 32)
         nAdr = 0;
         nCom = 0;
         memcpy(&nAdr, szNEC, 1);
         for(k=0;k<8;k++)
            szNEC[k] = szNEC[16+k];
         memcpy(&nCom, szNEC, 1);
         lcd_gotoxy(1,3);
         printf(lcd_putc, "Adresse = %02X", nAdr);
         lcd_gotoxy(1,4);
         printf(lcd_putc, "Commande = %02X", nCom);
         /*We also tell the mesh radio to send this to the other one (1 = pc)*/
         szMesh[1] = 0x0E;   //Lengh
         szMesh[2] = 0x11;   //Type ML_TRANSMIT
         //Parameters
         szMesh[4] = 0x01;   //Long Adress mode
         szMesh[5] = 0x00;   //Mesh radio mac 1 is the PC
         szMesh[6] = 0x14;
         szMesh[7] = 0x77;
         szMesh[8] = 0x00;
         szMesh[9] = 0x00;
         szMesh[10] = 0x00;
         szMesh[11] = 0x00;
         szMesh[12] = 0x03;
         szMesh[13] = 0x4;   //Two byte to send
         /*szMesh[14] = nAdr&0xff;
         szMesh[15] = nCom&0xff;
         szMesh[14] = 0x59;
         szMesh[15] = 0x1e;
         szMesh[16] = 0;      //CheckSum
         CheckRom(szMesh, 16);
         nSeq ++;
       //  for(k=0;k<17;k++)
       //     putc(szMesh[k]);
      /*   szMesh[0] = 0xA5;    //Sync
         for(k=0;k<4;k++)
            szMesh[4] += szMesh[k];
         szMesh[4] ^= 0xFF;
         szMesh[4]++;
         nSeq ++;
         for(k=0;k<5;k++)
            putc(szMesh[k]);*/
         while(!nReady)
            delay_us(100);
         nReady = 0;
         lcd_gotoxy(1,2);
         if(szAnswer[2] == 3)   //If PENDING
            printf(lcd_putc, "PEND ");
            while(!nReady)
               delay_us(100);
            nReady = 0;
            if(szAnswer[2] == 0)   //If Sucess
               printf(lcd_putc, "Sucess");
            printf(lcd_putc, "Error %x", szAnswer[3]);
         j = 0;
Set port direction
We set a timer for the remote decoding
void InitPic(void)
   setup_adc(ADC_OFF);
   set_tris_a(0x04);//A2 as input
   set_tris_c(0x80);//Rx(C7) as input
   output_high(PIN_A1);
   delay_ms(5);
   //Set timer 0 in 16 bit to count the uS between input
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);   //1 at timer value mean 2uS
   set_timer0(0);
   //Set timer 1 to make the led flash
   set_timer1(15536);
   //Empty the rx buffer (how could data be in)
   while(kbhit())
      getc();
   //Interrupt in RX for RS232
   nPos = 0;
   enable_interrupts(INT_RDA);
Interrupt when something is received by rs232
#INT_RDA
   unsigned char nChar;
   do
      nChar = getc();
      if((nChar == 0xA5)&&(nPos == 1))
         nPos = 0;
      szAnswer[nPos] = nChar;
      if(nPos >= 1)
         if (nPos == szAnswer[1]+2)
            nReady++;
            nPos = 0;
      nPos++;
   }while(kbhit());
   clear_interrupt(INT_RDA);
Interrupt of timer 1
We toogle the led and reset it
#INT_TIMER1
   output_toggle(PIN_A4);
   set_timer1(15536);
   clear_interrupt(INT_TIMER1);
Calculate the checksum for mesh radio
   int i;
    szTx[nNum] = 0;
    for(i=0;i<nNum;i++)
        szTx[nNum] += szTx[i];
    szTx[nNum] ^= 0xFF;
    szTx[nNum]++;
I know it pass by the putc function since my lcd show the message
so why its not transmitting anything?
PostPosted: Fri Nov 07, 2008 2:45 pm     Reply with quote
Make a small test program that works. Then add in portions of your
code until it fails. Then you will know the section of code that is causing
the problem.
Juls
PostPosted: Fri Nov 07, 2008 7:20 pm     Reply with quote
I will try this probably monday
so you are telling me that the uart part is ok?
PostPosted: Fri Nov 07, 2008 9:14 pm     Reply with quote
No. I'm saying that you need to prove that the UART works OK
in a small test program. Then start adding in the other parts of
your code.
Juls
PostPosted: Wed Nov 12, 2008 3:38 pm     Reply with quote
do work now
in the use
I never said UART1
