My mmc can't save information!!!
PostPosted: Fri Nov 07, 2008 3:04 am     Reply with quote
Hi
I wrote this code with the mmcsd.c library, but I don't know why it doesn't work.
#include "mmc.h"
#include "mmcsd.c"
#include "input.c"
   char str[100];
   byte a;
   char T;
   int16 i;
   mmcsd_init();
      if (mmcsd_init())
      printf("Could not init the MMC/SD!!!!");
      while(TRUE);
     printf("READ OR WRITE???:-->\r\n");
       T=getc();
     putc(T);
     if (T=='w')
        printf("\r\nYour Text:\r\n");
        get_string(str, 20);
        for(i=0;i<=60;i++)
          mmcsd_write_byte(i,str[i]);
          delay_ms(1);
        mmcsd_flush_buffer();
        printf("\r\nwrite finished!!\r\n");
     if (T == 'r')
       for(i=0;i<=1000;i++)
          mmcsd_read_byte(i,&a);
          printf("%c",a);
       printf("\r\n");
For example in this code I write 'w' to write a string with 20 character length. I do it and write 'r' for read and it works very well. But when I want to read this string from MMC for a second time, the PIC returns NULL characters.
I tested the "ex_mmcsd.c" example and I get same result. Do you know where the problem is, and what's the correct way ?
PostPosted: Fri Nov 07, 2008 11:53 am     Reply with quote
Always post your compiler version number.
Most likely you have a problem in the hardware connection to the MMC/SD card. Expand your program to show the result of the mmcsd_flush_buffer() call, if this is unequal to zero you have a hardware problem.
There are at least two problems with the CCS mmcsd driver in v4.077.
Check out some hints in this thread
PostPosted: Tue Nov 11, 2008 11:15 am     Reply with quote
I use 4.057.
But I can't get result and simulate it with Proteus.
