jgoss Guest
Looking for any monitor routines |
Posted: Thu Jan 23, 2003 5:35 pm |
I am about ready to write some RS232 monitor routines to make an easy way of monitoring & controlling my project. I was wondering if anybody out there has already done something like this, so I don't have to totally re-invent the wheel.
I am thinking along the lines of a simple one or two letter command input gets me some function output such as:
? gives me the menu
The menu may look something like:
D = Dump EEPROM
L = Data Log dump
V = Read Voltage
C = Read Current
If anyone has done something like this I would sure like to get a copy.
Thanks,
John Goss
___________________________
Original Post ID: 10954 |
Steve H Guest
What I do..... |
Posted: Thu Jan 23, 2003 7:35 pm |
John: You can look at a simple command parser that I have used for many projects.
Check out the link below, on that page you can download the source code....
Regards,
Steve H
Original Post ID: 10955 |
Neutone
More than you wanted |
Posted: Fri Jan 24, 2003 9:40 am |
This is what I am using to perform software debugging. I have access to every variable in ram with these two function. The first function sets up the data transfer. The second function moves data. I can process around 10 packets per second at 9600 baud. I'm planning to writeup a project using a pic to aquire 8 analog bytes and 8 bits making a poor mans logic analizer/scope. I plan to release well documented source for the pic and sell the PC interface. I also plan to include source for interupt driven serial packet handeling as well. Making a complete developers toolkit. You may be able to adapt some of this to your purpose.
* MODBUS Function code 66 (custom) Debug Write Table of PIC RAM Addresses *
// Debug Write Table of PIC RAM Addresses
// INPUT: Addresses of the 8 data bytes
// PacketBuff[2] is Hi address byte of 1st data byte
// PacketBuff[3] is Low address byte of 1st data byte
// PacketBuff[4] is Hi address byte of 2nd data byte
// PacketBuff[5] is Low address byte of 2nd data byte
// PacketBuff[6] is Hi address byte of 3rd data byte
// PacketBuff[7] is Low address byte of 3rd data byte
// PacketBuff[8] is Hi address byte of 4th data byte
// PacketBuff[9] is Low address byte of 4th data byte
// PacketBuff[10] is Hi address byte of 5th data byte
// PacketBuff[11] is Low address byte of 5th data byte
// PacketBuff[12] is Hi address byte of 6th data byte
// PacketBuff[13] is Low address byte of 6th data byte
// PacketBuff[14] is Hi address byte of 7th data byte
// PacketBuff[15] is Low address byte of 7th data byte
// PacketBuff[16] is Hi address byte of 8th data byte
// PacketBuff[17] is Low address byte of 8th data byte
// Each pair of bytes below pertains to one bit of the 9th data byte.
// The high order address byte uses its low 5 bits for the address and the high 3 bits for the bit number within the byte
// PacketBuff[18] is Hi address byte of 9th data byte bit 0. High 3 bits for bit number
// PacketBuff[19] is Low address byte of 9th data byte
// PacketBuff[20] is Hi address byte of 9th data byte bit 1. High 3 bits for bit number
// PacketBuff[21] is Low address byte of 9th data byte
// PacketBuff[22] is Hi address byte of 9th data byte bit 2. High 3 bits for bit number
// PacketBuff[23] is Low address byte of 9th data byte
// PacketBuff[24] is Hi address byte of 9th data byte bit 3. High 3 bits for bit number
// PacketBuff[25] is Low address byte of 9th data byte
// PacketBuff[26] is Hi address byte of 9th data byte bit 4. High 3 bits for bit number
// PacketBuff[27] is Low address byte of 9th data byte
// PacketBuff[28] is Hi address byte of 9th data byte bit 5. High 3 bits for bit number
// PacketBuff[29] is Low address byte of 9th data byte
// PacketBuff[30] is Hi address byte of 9th data byte bit 6. High 3 bits for bit number
// PacketBuff[31] is Low address byte of 9th data byte
// PacketBuff[32] is Hi address byte of 9th data byte bit 7. High 3 bits for bit number
// PacketBuff[33] is Low address byte of 9th data byte
// OUTPUT: Store the 32 input bytes into RAM to define the location of 9 data bytes, the 9th bite is for 8 separately located bits
// Set PacketBuffSize to 33 (the offset of the last data byte which is unchanged from when input)
void Debug_Load_Addresses(void) // MODBUS Function code 66. Debug Write Table of PIC RAM Addresses
{ memcpy( Lookup_Table, &PacketBuff[2], 32 ); // move the 32 input bytes into RAM to define the location of 9 data bytes
PacketBuffSize = 33; // Index of packets last byte, needed for CRC
debug_66_initialized = 1; // set flag that the Lookup_Table was initialized
* MODBUS Function code 67 (custom) Debug Read or Write 9 bytes from/to PIC RAM. Then send result to input device *
// Debug Read & send 9 bytes from PIC RAM or instead write 9 bytes to PIC RAM followed by reading it back and sending it to input device
// INPUT: If PacketBuff[11] is nonzero, the following 9 bytes are input:
// PacketBuff[2] is the 1st data byte (to be writen to PIC RAM)
// PacketBuff[3] is the 2nd data byte (to be writen to PIC RAM)
// PacketBuff[4] is the 3rd data byte (to be writen to PIC RAM)
// PacketBuff[5] is the 4th data byte (to be writen to PIC RAM)
// PacketBuff[6] is the 5th data byte (to be writen to PIC RAM)
// PacketBuff[7] is the 6th data byte (to be writen to PIC RAM)
// PacketBuff[8] is the 7th data byte (to be writen to PIC RAM)
// PacketBuff[9] is the 8th data byte (to be writen to PIC RAM)
// PacketBuff[10] is the 9th data byte (to be writen to PIC RAM as independent bits)
// If PacketBuff[11] is 0, the above bytes are not used
// OUTPUT: The device that sends this command to this PIC chip (CCM) requests either of two commands:
// (1) read 9 bytes from PIC RAM and send this to the calling device.
// (2) write 9 bytes to PIC RAM and then read this back from PIC RAM and send this to the calling device.
// For fucntion (1) above PacketBuff[11] is 0 as input.
// For fucntion (2) above PacketBuff[11] is nonzero as input.
// Whichever function is requested, it is done according to the table of PIC RAM Addresses loaded from the last Modbus function 66.
// The following packet is sent to the input device:
// PacketBuff[10] is the 9th data byte, but composed from 8 scattered bits from 8 independent addresses (see function code 66)
// PacketBuffSize is 10, the offset of the last data byte
void Debug_Read_Write(void) // MODBUS Function code 67. Debug Read or Write 9 bytes from/to PIC RAM. Then send result to input device
{ int8 i, k, high;
int16 addr;
int8 const mask_array_set[8] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
int8 const mask_array_clear[8] = { 0xFE, 0xFD, 0xFB, 0xF7, 0xEF, 0xDF, 0xBF, 0x7F };
int8 y, z;
if ( !debug_66_initialized ) // if Lookup_Table is NOT loaded
{ PacketBuff[1] = PacketBuff[1] + 128; // COMMAND NOT SUPPORTED YET
PacketBuff[2] = 0x01; // send trivial packet
PacketBuffSize = 2;
return;
if ( PacketBuff[11] ) // if input command is writing and then reading it back out
{ // Write 8 bytes to PIC RAM according to the Table of PIC RAM Addresses loaded from the last Modbus function 66
for ( i = 0, k = 2; k < 10; i += 2, k++ ) // write first 8 bytes
{ addr = make16( Lookup_Table[i], Lookup_Table[i+1] ); // obtain address of next location
*addr = PacketBuff[k]; // insert byte into table
// Write 9th byte as 8 bits to PIC RAM according to the Table of PIC RAM Addresses loaded from the last Modbus function 66
y = PacketBuff[10];
for ( i = 16; i < 33; i += 2 ) // write 9th byte as 8 separate bits
{ high = Lookup_Table[i] & 0x01F; // isolate the high order 5 bits of the 13 bit address
addr = make16( high, Lookup_Table[i+1] ); // obtain address of the byte for the next bit
z = Lookup_Table[i]>>5;
if ( bit_test( y, 0 ) ) *addr = *addr | mask_array_set[ z ]; // if input bit is set, set the table bit
else *addr = *addr & mask_array_clear[ z ]; // if bit is clear, clear the table bit
y = y>>1;
// Logic common to both input fucntions: reading from PIC RAM
// Read 8 bytes from PIC RAM according to the Table of PIC RAM Addresses loaded from the last Modbus function 66
for ( i = 0, k = 2; k < 10; i += 2, k++ ) // read first 8 bytes
PacketBuff[k] = *addr; // insert byte into output buffer
PacketBuff[10] = 0; // initialize so we only need to set bits (not clear bits)
// Read 9th byte from PIC RAM as 8 bits according to the Table of PIC RAM Addresses loaded from the last Modbus function 66
for ( i = 16, k = 0; k < 8; i += 2, k++ ) // read 9th byte as 8 separate bits
if ( *addr & mask_array_set[ Lookup_Table[i]>>5 ] ) // if result bit is set
PacketBuff[10] = PacketBuff[10] | mask_array_set[ k ]; // set the output bit
// NOT NEEDED DUE TO INITIALIZATION: else PacketBuff[10] &= mask_array_clear[ k ]; // clear the output bit
PacketBuffSize = 10; // Index of packet's last byte, needed for CRC
Original Post ID: 10968 |
Hans Wedemeyer Guest
Re: Looking for any monitor routines |
Posted: Fri Jan 24, 2003 4:11 pm |
Not knowing the details of your project other than
what you have mnentioned here.
Have you looked at or considered MODBUS ?
For simple items like Read Voltage, Read Current, etc. it sounds like MODBUS to me.
More info at
<a href="http://www.modbus.org/default.htm" TARGET="_blank">http://www.modbus.org/default.htm</a>
Original Post ID: 10979 |
john Goss Guest
Re: What I do..... |
Posted: Fri Jan 24, 2003 5:15 pm |
Thanks guys, this helps
:=John: You can look at a simple command parser that I have used for many projects.
:=Check out the link below, on that page you can download the source code....
:=Regards,
:=Steve H
Original Post ID: 10983 |
