Suggestion regarding picmicro
Guest New
PostPosted: Wed Nov 05, 2008 12:28 pm     Reply with quote
Hi.
I need to develop some voice processing software.
Simple explanation:
MIC -- CHIP -- AMPLIFIER -- SPEAKER
Power supply : 3V
My job is to process all incoming voice, set some filter, send to output.
Am using picdem2 demo board so I can test just those MCU's.
Main goal is to process as much as possible data thru chip.
What chip should I choose ?
PostPosted: Wed Nov 05, 2008 4:24 pm     Reply with quote
Select your sample rate for audio. Let's say you choose 8 KHz.
The period is 125 us. All of your operations have to be done
in that time period. This includes the A/D conversion. Now
consider that if you run a PIC at 20 MHz, you get 5 instruction
cycles per microsecond (us). So you have 625 instruction cycles
to take a sample, process it, and write it to the (external) D/A.
Write your program, and run the MPLAB MPSIM profile menu
and see how many instruction cycles it takes to execute your code.
If it takes too many, you can reduce your code or use a PIC with
a higher oscillator speed (40 MHz).
Guest New
PostPosted: Thu Nov 06, 2008 2:44 am     Reply with quote
I would take 40 MHz.
Maybe some 18F or better PIC24 ?
PIC24H should be OK but i dont know if i can use PICDEM 2 with it?
ww*w*.microchip.com/ParamChartSearch/chart.aspx?branchID=8186&mid=14&lang=en&pageId=75
What do you think about that choice. Do you have some other idea ?
SherpaDoug
PostPosted: Thu Nov 06, 2008 7:10 am     Reply with quote
This is just the sort of application a DSPic was born to do. Please consider them.
Guest New
PostPosted: Fri Nov 07, 2008 1:28 am     Reply with quote
Can I use dsPic with PICDEM 2 PLus and ICD debugger ?
PostPosted: Fri Nov 07, 2008 1:44 am     Reply with quote
Sherpa,
Have you been reading FvM's posts ? Do a search for PCD and put FvM
in as the author.
SherpaDoug
PostPosted: Fri Nov 07, 2008 6:46 am     Reply with quote
OK, so I guess PCD is not yet ready for prime time. Newbies should probably stay clear of it for a few months. I do intend to get it the next time I upgrade my CCS.
Guest New
PostPosted: Fri Nov 07, 2008 2:43 pm     Reply with quote
So suggestion would be something in PIC24H line ?
I can't find any device support list for PICDEM 2 but i guess that PIC24H should be supported ?
PostPosted: Mon Nov 10, 2008 11:19 pm     Reply with quote
To Sherpa:
I emailed CCS a list of all of FvM's bug reports on PCD. They emailed
me back an ID number for the bug report. So at least now they know
about the bugs. Hopefully they will fix them.
