I got this problem, my compiler (PCM 4.057) did not generate the .hex file, it generated only two object files, this happened today, however yesterday it was working fine ?, what´s wrong with it ? what should I do ?
thanks.
Posted: Tue Nov 04, 2008 4:00 pm
Re-install the compiler. Make sure the file compiles with no errors.
Make sure that you're looking for the HEX file in the actual project
directory, and not in some other directory.
