DS1307 Set Command need help
Don_J
PostPosted: Tue Nov 04, 2008 9:51 am     Reply with quote
I am trying to write a pgm to set the ds1307 interactively from a serial connection. I want to print a request, wait for input (two digits) and update the variable. I would repeat this for the year, month, day, dow, hr, min, and sec. I tried using the gethex to input the digits. The problem is when I pass this to the DS1307 it sets the wrong time. If I set the variables manually (BYTE sec=22, as an example it works OK).
Does anyone have code to set the ds1307 interactively via a serial connection?
I am using the PCWHD version 4.073 and the processor is a 16F886.
The following is a snip of the code I was using:
  BYTE sec;
  BYTE min;
   printf("\r\n\Enter 2 digits for the Seconds = ");
   sec=gethex();
   printf("\r\n\Enter 2 digits for the Minutes = ");
   min=gethex();
  ds1307_set_date_time(29,10,98,04,16,min,sec);
PostPosted: Tue Nov 04, 2008 10:55 am     Reply with quote
The 'set_date_time' function, contains code to convert the incoming numbers into_ the BCD format needed by the chip.
22Hex (which is what gethex will read the value '22' as), is 34 decimal. The time will get set to 34 minutes, not 22 minutes using this code.
You either need to just read the value as ASCII, perform a conversion from BCD hex to decimal with the existing code, or use your own version of the set_date_time function, that does not perform the BCD conversion.
Don_J
PostPosted: Tue Nov 04, 2008 11:30 am     Reply with quote
Thank you! That's great. I modified the driver and it works.
Where would I find more info on this "perform a conversion from BCD hex to decimal "?
PostPosted: Tue Nov 04, 2008 12:33 pm     Reply with quote
For example, in the same location where you found the driver to write to the DS1307... Rolling Eyes
It looks like your driver comes out of this thread: http://www.ccsinfo.com/forum/viewtopic.php?t=23255
Scroll a bit down and you will find the functions bin2bcd() and bcd2bin().
Or use the search function of this forum...
More examples:
A version with multiply and mod, short notation, large code.
A version using shifts instead of multiply. Longer notation but faster code on a PIC16 which has no hardware multiply.
Don_J
PostPosted: Tue Nov 04, 2008 12:48 pm     Reply with quote
Thanks so much, you have been a big help.
