rnielsen
Infrared parts inquiry |
Posted: Fri Oct 31, 2008 12:21 pm |
This post is a bit off topic, even though the circuit does include a PIC. I'm searching for a good matched pair of infrared emitter & transistor. They both need to be thru-hole components with the transistor in a TO-18 case. I'm sure that there's a few good folks here that's done a project or two utilizing them.
I will be using the pair to detect something interrupting the light hitting the transistor. They will be approximately 7 inches apart and the transistor will be driving a comparator.
I've looked at several components but I thought I would ask here to make sure I was able to find the best solution.
Thanks in advanced.
Ronald |
