I/O and ADC issues w/16F887 using Device editor
Goto page 1, 2  Next
coderchick
PostPosted: Thu Oct 30, 2008 1:16 pm     Reply with quote
Hi all!
I have an older version of the PCWH compiler (3.245) and attempted to use the Device editor to setup use for the 16F887 with the modified *.h file listed at the end of this message. Everything seemed to be fine, my code compiled and seemed to run with no apparent issues. However, after hooking it up to the debugger and an o-scope, I found that my I/O pins are not functioning correctly. They are neither high nor low, but kinda float somewhere in the middle, and when I try to drive them high or low, nothing happens. My ADC pin seems to be acting the same way, and not reading in the appropriate values.
I've checked my circuit, and there doesn't appear to be any shorts anywhere that may be causing this, and I have a full 5V power supply hooked up to it. So, I don't think it's my circuit that is causing the problems.
Following is the first section of my main code, the fuses that I have set for it, and a small list from the Device editor on how I've set up the A/D converter section. Can anyone check this out for me and see if I've missed something?
Device Editor A/D Converter section
A/D Converter
       ADC Channels             14
       Go/Done Bit              ADCON0:1
       Clock Select             C1:6, C0:6-7
       Result Format            C1:7
       Channel LSB              Bit 2
       Pins Select              C1:0-5_ABE
       ADC Regs                  1F, 0, 9F, 9E, 1E
       ADC Bits                 10
       Continuous Loop          False
partial main loop
   signed int16 new_value = 100;                   //placeholder for contrast
   int16 current_contrast;
   signed int16 adjust;                             //adjustment of brightness
   signed int16 current_brightness;
   setup_adc_ports(AN0|VSS_VDD);             //set up ADC port RA0
   setup_adc(ADC_CLOCK_INTERNAL); //acquisition time for analog pins
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);//~65.5 ms
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);   //~524 ms
   setup_timer_2(T2_DIV_BY_4,60,1);          //used for PWM routine
   enable_interrupts(INT_EXT);
   ext_int_edge( H_TO_L );
   output_high(VIDEO_ENABLE);
header and fuses setup
#include <16F887.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES PUT                      //Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
/****PIN DEFINITIONS****/
#define ADC           PIN_A0
#define VIDEO_ENABLE  PIN_A4
#define STATUS        PIN_A5
#define LEAK_DETECT   PIN_B0  //external interrupt
#define GRN_LED       PIN_B1
#define RED_LED       PIN_B2
#define CONTRAST_UP   PIN_B4
#define CONTRAST_DWN  PIN_B5
#define BUZZ1   PIN_C1
#define BUZZ2   PIN_C2
#define TX      PIN_C6 //for RS232 communication?
#define RX      PIN_C7 //for RS232 communication?
#define FULL_LED  PIN_D0
#define LOW_LED   PIN_D1
#define MID_LED   PIN_D2
#define BAT_IR_OUT  PIN_E0
16F887.h
//////// Standard Header file for the PIC16F887 device ////////////////
#device PIC16F887
#nolist
//////// Program memory: 8192x14  Data RAM: 271  Stack: 8
//////// I/O: 36   Analog Pins: 14
//////// Data EEPROM: 256
//////// C Scratch area: 77   ID Location: 2000
//////// Fuses: LP,XT,HS,EC_IO,INTRC_IO,INTRC,RC_IO,RC,NOWDT,WDT,NOPWRT,PWRT
//////// Fuses: NOMCLR,MCLR,NOCP,CP,NOCPD,CPD,NOBROWNOUT,BROWNOUT
//////// Fuses: BROWNOUT_NOSL,BROWNOUT_SW,NOIESO,IESO,NOFCMEN,FCMEN,NOLVP
//////// Fuses: LVP,NODEBUG,DEBUG,BOR4VBROWNOUT_SL,BOR2V,WRT2,WRT1,WRT0
//////// Fuses: NOWRT
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         PORT_x_PULLUPS(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_A6  46
#define PIN_A7  47
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_D0  64
#define PIN_D1  65
#define PIN_D2  66
#define PIN_D3  67
#define PIN_D4  68
#define PIN_D5  69
#define PIN_D6  70
#define PIN_D7  71
#define PIN_E0  72
#define PIN_E1  73
#define PIN_E2  74
#define PIN_E3  75
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int
#define BOOLEAN short int
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP  3
#define WDT_TIMEOUT     11
#define MCLR_FROM_SLEEP 19
#define MCLR_FROM_RUN   27
#define NORMAL_POWER_UP 24
#define BROWNOUT_RESTART 26
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER_0() are:
#define RTCC_INTERNAL   0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
#define WDT_ON          1
#define WDT_OFF         0
#define WDT_DIV_32      1
#define WDT_DIV_64      3
#define WDT_DIV_128     5
#define WDT_DIV_256     7
#define WDT_DIV_512     9
#define WDT_DIV_1024    11
#define WDT_DIV_2048    13
#define WDT_DIV_4096    15
#define WDT_DIV_8192    17
#define WDT_DIV_16394   19
#define WDT_DIV_32768   21
#define WDT_DIV_65536   23
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         0x85
#define T1_EXTERNAL         0x87
#define T1_EXTERNAL_SYNC    0x83
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED         0
#define T2_DIV_BY_1         4
#define T2_DIV_BY_4         5
#define T2_DIV_BY_16        6
////////////////////////////////////////////////////////////////// CCP
// CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
// CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
// Constants used for SETUP_CCPx() are:
#define CCP_OFF                         0
#define CCP_CAPTURE_FE                  4
#define CCP_CAPTURE_RE                  5
#define CCP_CAPTURE_DIV_4               6
#define CCP_CAPTURE_DIV_16              7
#define CCP_COMPARE_SET_ON_MATCH        8
#define CCP_COMPARE_CLR_ON_MATCH        9
#define CCP_COMPARE_INT                 0xA
#define CCP_COMPARE_RESET_TIMER         0xB
#define CCP_PWM                         0xC
#define CCP_PWM_PLUS_1                  0x1c
#define CCP_PWM_PLUS_2                  0x2c
#define CCP_PWM_PLUS_3                  0x3c
long CCP_1;
#byte   CCP_1    =                      0x15
#byte   CCP_1_LOW=                      0x15
#byte   CCP_1_HIGH=                     0x16
// The following should be used with the ECCP unit only (or these in)
#define CCP_PWM_H_H                     0x0c
#define CCP_PWM_H_L                     0x0d
#define CCP_PWM_L_H                     0x0e
#define CCP_PWM_L_L                     0x0f
#define CCP_PWM_FULL_BRIDGE             0x40
#define CCP_PWM_FULL_BRIDGE_REV         0xC0
#define CCP_PWM_HALF_BRIDGE             0x80
#define CCP_SHUTDOWN_ON_COMP1           0x100000
#define CCP_SHUTDOWN_ON_COMP2           0x200000
#define CCP_SHUTDOWN_ON_COMP            0x300000
#define CCP_SHUTDOWN_ON_INT0            0x400000
#define CCP_SHUTDOWN_ON_COMP1_INT0      0x500000
#define CCP_SHUTDOWN_ON_COMP2_INT0      0x600000
#define CCP_SHUTDOWN_ON_COMP_INT0       0x700000
#define CCP_SHUTDOWN_AC_L               0x000000
#define CCP_SHUTDOWN_AC_H               0x040000
#define CCP_SHUTDOWN_AC_F               0x080000
#define CCP_SHUTDOWN_BD_L               0x000000
#define CCP_SHUTDOWN_BD_H               0x010000
#define CCP_SHUTDOWN_BD_F               0x020000
#define CCP_SHUTDOWN_RESTART            0x80000000
#define CCP_DELAY                       0x1000000  // Multiply this by the delay count
long CCP_2;
#byte   CCP_2    =                      0x1B
#byte   CCP_2_LOW=                      0x1B
#byte   CCP_2_HIGH=                     0x1C
////////////////////////////////////////////////////////////////// SPI
// SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
// Constants used in SETUP_SPI() are:
#define SPI_MASTER       0x20
#define SPI_SLAVE        0x24
#define SPI_L_TO_H       0
#define SPI_H_TO_L       0x10
#define SPI_CLK_DIV_4    0
#define SPI_CLK_DIV_16   1
#define SPI_CLK_DIV_64   2
#define SPI_CLK_T2       3
#define SPI_SS_DISABLED  1
#define SPI_SAMPLE_AT_END 0x8000
#define SPI_XMIT_L_TO_H  0x4000
////////////////////////////////////////////////////////////////// UART
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE  - Turn UART on
#define UART_ADDRESS           2
#define UART_DATA              4
#define UART_AUTODETECT        8
#define UART_AUTODETECT_NOWAIT 9
#define UART_WAKEUP_ON_RDA     10
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparator() are:
#define A0_A3_A1_A2  0xfff04
#define A0_A2_A1_A2  0x7ff03
#define NC_NC_A1_A2  0x6ff05
#define NC_NC_NC_NC  0x0ff07
#define A0_VR_A1_VR  0x3ff02
#define A3_VR_A2_VR  0xcff0A
#define A0_A2_A1_A2_OUT_ON_A3_A4 0x7e706
#define A3_A2_A1_A2  0xeff09
#bit C1OUT = 0x1f.6
#bit C2OUT = 0x1f.7
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0          // ADC Off
#define ADC_CLOCK_DIV_2    0x100
#define ADC_CLOCK_DIV_8     0x40
#define ADC_CLOCK_DIV_32    0x80
#define ADC_CLOCK_INTERNAL  0xc0          // Internal 2-6us
// Constants used in SETUP_ADC_PORTS() are:
//#define sAN0                   1         //| A0
//#define sAN1                   2         //| A1
//#define sAN2                   4         //| A2
//#define sAN3                   8         //| A3
//#define sAN4                  16         //| B0
//#define sAN5                  32         //| B1
//#define sAN6                  64         //| B2
//#define sAN7                  128        //| B3
#define AN0                   1         //| A0
#define AN1                   2         //| A1
#define AN2                   4         //| A2
#define AN3                   8         //| A3
#define AN4                  16         //| B0
#define AN5                  32         //| B1
#define AN6                  64         //| B2
#define AN7                  128        //| B3
#define NO_ANALOGS             0         // None
#define ALL_ANALOG            255        // A0 A1 A2 A3 B0 B1 B2 B3
// The following may be OR'ed in with the above using |
#define VSS_VDD              0x0000  // Range 0-Vdd
#define VSS_VREF             0x1000  // Range 0-Vref1
#define VSS_VR               0x2000  // Range 0-Vr
#define VSS_VDAC             0x3000  // Range 0-Vdac
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
////////////////////////////////////////////////////////////////// INT
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x0B20
#define INT_RB                    0xFF0B08
#define INT_EXT                   0x0B10
#define INT_AD                    0x8C40
#define INT_TBE                   0x8C10
#define INT_RDA                   0x8C20
#define INT_TIMER1                0x8C01
#define INT_TIMER2                0x8C02
#define INT_CCP1                  0x8C04
#define INT_CCP2                  0x8D01
#define INT_SSP                   0x8C08
#define INT_BUSCOL                0x8D08
#define INT_EEPROM                0x8D10
#define INT_TIMER0                0x0B20
#define INT_OSC_FAIL              0x8D80
#define INT_COMP                  0x8D20
#define INT_COMP2                 0x8D40
#list
KMoe
~We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little. We are now qualified to do anything with nothing -M. Theresa
PostPosted: Thu Oct 30, 2008 1:23 pm     Reply with quote
#FUSES LVP
That fuse is probably the reason. Set it to NOLVP. Do that in all your
programs.
Also make sure you have a pull-up resistor on the MCLR pin.
Use 10K for the ICD2, or 47K for the ICD-U40.
coderchick
PostPosted: Thu Oct 30, 2008 1:45 pm     Reply with quote
programs.
I've changed the fuse to NOLVP and the I/O pins are still funky
I have two 24K resistors in series for my ICD-U40 instead of one 47k, would that really cause that much of a difference?[/quote]
KMoe
ECACE
PostPosted: Thu Oct 30, 2008 1:55 pm     Reply with quote
I would suggest you start with a very simple LED blink program, just to remove all possibliity of it being your code.
I'm not sure what will happen if you create your own file for a processor that came out that much later than your complier.
Someone with more experience in that arena will hopefully speak up.
A HW Engineer 'trying' to do SW !!! Run!!!
PostPosted: Thu Oct 30, 2008 2:01 pm     Reply with quote
See this thread for a simple LED blinking program.
http://www.ccsinfo.com/forum/viewtopic.php?t=36109
coderchick
PostPosted: Thu Oct 30, 2008 4:33 pm     Reply with quote
ok, so the snippet of code PCM suggested worked, the little LED flashed, yippee! Jubilation! After that I was hopeful and changed it to only turn on the LED when the button on B4 is pressed (see below)
      if (input(PIN_B4) == 0)
         output_high(PIN_B0);
         //delay_ms(500);
         output_low(PIN_B0);
         //delay_ms(500);
However, when I ran the debugger, it turned the LED on right away and no amount of button pressing changed it. The button is very simple, one end is connected to ground and the other to B4, when the button is pressed, it connects the two lines. Yet, the pin constantly reads 0 or 0.134, either way it's still 0 and the LED turns on, which shouldn't be happening because the button isn't pushed. I've checked with a multimeter and there is no shorting within the button, so what could be causing the pin to read low??
KMoe
PostPosted: Thu Oct 30, 2008 5:05 pm     Reply with quote
You need a pull-up resistor on the input pin. The pull-up maintains a high
logic level on that pin when the button is not pressed. Either add an
external pullup (10K) or enable the built-in Port B pull-ups.
See the CCS manual for the function to do that.
coderchick
PostPosted: Thu Oct 30, 2008 5:08 pm     Reply with quote
hm, will all my input pins need pull-up resistors?
KMoe
PostPosted: Thu Oct 30, 2008 5:15 pm     Reply with quote
Any pin that has a switch or a button on it will need one.
coderchick
PostPosted: Thu Oct 30, 2008 5:47 pm     Reply with quote
alright, that makes sense, but things are still not working. Through the multimeter, I can see the voltage go from 5.08 to 0.00 when the button is pressed, but according to the debugger, that pin on the port never changes.
KMoe
PostPosted: Thu Oct 30, 2008 6:45 pm     Reply with quote
Because you added this PIC to the compiler, there may be a problem
in the device data. Compile the program below and look at the end of
the .LST file. Post the fuse settings. It should look like this:
Configuration Fuses:
Word 1: 2FE4 INTRC_IO NOWDT PUT MCLR NOPROTECT NOCPD BROWNOUT IESO FCMEN NOLVP NODEBUG
Word 2: 3FFF NOWRT BORV40
#include <16F887.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, MCLR, NOLVP
port_b_pullups(TRUE);
    if(input(PIN_B4) == 0)
        output_low(PIN_B0);
coderchick
PostPosted: Fri Oct 31, 2008 2:15 pm     Reply with quote
#include <16F887.h>
output_low(PIN_B0);
Right off the bat, my compiler was giving me an error stating that MCLR and INTRC_IO are unknown keywords. I assume that's a bad thing. I commented that part out to look like below:
#include <16F887.h>
#fuses /*INTRC_IO,*/ NOWDT, PUT, BROWNOUT, /*MCLR,*/ NOLVP
        output_low(PIN_B0);
and this is what the list file showed for the fuses:
Word 1: 3F73 RC NOWDT PUT NODEBUG NOPROTECT BROWNOUT NOLVP NOCPD NOWRT
but again, because it did not understand INRC_IO or MCLR, I would assume something is wrong...?
KMoe
PostPosted: Fri Oct 31, 2008 2:30 pm     Reply with quote
If you are adding a new PIC with the Device Editor, I think you must
add the appropriate fuses and their Masks and Values.
This is shown in the upper right corner of this screenshot:
http://www.ccsinfo.com/images/content/device_editor.gif
I suspect that a lot of your problems are caused by incomplete
or incorrect entries in the Device Data for the 16F887 -- especially
in the fuses section. Every fuse in that section should be carefully
checked against the Config Bits section of the 16F887 data sheet.
treitmey
PostPosted: Fri Oct 31, 2008 2:35 pm     Reply with quote
Would it be inappropriate to show the fuses??
I just finished doing this same thing for this same chip.
But I had version 4.x to copy from.
PostPosted: Fri Oct 31, 2008 2:39 pm     Reply with quote
Are you asking if it's OK to post them ? Should be. The data comes
from the 16F887 data sheet. It's not proprietary to CCS.
Goto page 1, 2  Next
Page 1 of 2
