serial
elseus
serial
PostPosted: Mon Oct 27, 2008 3:34 pm     Reply with quote
Hi
I'm new beginner to using CCS and I need help for a problem. I think there isn't scanf() in ccs. Is there somebody to help me about that problem? Confused
#include <stdio.h>
#include <string.h>
int32 x;
int16 y;
int16 z;
while (true)
      x=245948;
      y=1239;
      z=3599;
How can I send this 3 variable to other pic serially and how
can I take these 3 variables in other pic and separate them
in there ? ( 2x 16f877A using)
ECACE
PostPosted: Mon Oct 27, 2008 6:29 pm     Reply with quote
If you don't have it already, download the current manual for the compiler, go to page 71. Read about the RS232 overview, then go to page 133 and read up on the #use RS232, lastly go through the examples in your PICC/Examples directory for RS232. Sorry, but you really have to read up on some of it so you really know what's going on in your program.
Short answer for your question, which you will need the above information, read up on the getc(). This will let you RX the data. Whereas putc() will let you send the data. Or to send it, you could use printf().
A HW Engineer 'trying' to do SW !!! Run!!!
PostPosted: Mon Oct 27, 2008 7:26 pm     Reply with quote
Drop "sscanf" (with two s's) in the search page. See what you find:
http://www.ccsinfo.com/forum/search.php
Elseus
PostPosted: Tue Oct 28, 2008 9:18 am     Reply with quote
Thanks for your messages.
I read about the RS232 overview and I look at examples and I much try
with putc( ) getc( ) puts gets fputs fgets printf fprintf... all, but I can send and take data byte - byte with these. Sad
I am beginner yet.
If somebody can write a little code for example I think I will understand
where is my mistake. I need help for this. Thanks all.
pattousai
PostPosted: Tue Oct 28, 2008 10:25 am     Reply with quote
hummm... i'm not understanding what are you trying to say...
you can't send and take data? Are you asking for example code using these functions?
if can somebody write little code for example I think I will understand
i think that the best way for us to help you is exactly that, pointing yours mistakes. but we need them (yours mistakes). So... put your code that you are trying to use these functions (go to the examples firectory).[/quote]
ECACE
PostPosted: Tue Oct 28, 2008 10:36 am     Reply with quote
Correct me if I am wrong, but is your question in regards to sending and receiving a 16 and 32 bit number when the RS-232 functions all are for 8 bits? We need more info before we can really help you.
Elseus
PostPosted: Tue Oct 28, 2008 4:42 pm     Reply with quote
first pic send code:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=3500000)
#use fast_io(b)
#define use_portb_lcd TRUE
#include <lcd.c>
int16 x;
int32 y;
  void main ( )
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_CCP2(CCP_OFF);
   set_tris_b(0x00);
x=3255;
y=142218;
     lcd_gotoxy(1,1);
printf(lcd_putc,"%ld,%ld"x,y);
     lcd_gotoxy(1,2);
puts(x);
puts(y);
second pic receive code:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#use delay (clock=3500000)#use fast_io(b)
#define use_portb_lcd TRUE  #include <lcd.c>
int16 x
int32 y;
  void main ( )
   setup_adc(ADC_OFF);
   set_tris_b(0x00);
 gets(x);
 gets(y);
      lcd_gotoxy(1,1);
     lcd_gotoxy(1,2);
thats all Confused
PostPosted: Tue Oct 28, 2008 4:53 pm     Reply with quote
There is no commercially available crystal or oscillator available in that
frequency, at least on a major supplier such as Digikey. I suppose you
could have one made at that frequency.
Is this a real hardware project ? Or is this being run in a simulator
such as Proteus ?
Elseus
PostPosted: Tue Oct 28, 2008 6:08 pm     Reply with quote
yes its a proteus smulation.
u can change frequency.
PostPosted: Tue Oct 28, 2008 6:13 pm     Reply with quote
int16 x
int32 y;
x=3255;
y=142218;
lcd_gotoxy(1,1);
lcd_gotoxy(1,2);
puts(x);
puts(y);
This part won't work. "puts" means "put string". But 'x' and 'y' are not
strings. They are integers. You need to use a printf() statement with
the "%lu\r" format specifiers. This will convert an integer to ASCII and
add a carriage return on the end, and transmit it out the rs232 port on
the PIC.
gets(x);
gets(y);
lcd_gotoxy(1,1);
lcd_gotoxy(1,2);
This is your receiver code. It won't work. You are receiving ASCII
strings. You don't display strings with "%ld". You display them
with "%s". Read the CCS manual or read this Wikipedia article to
find out more about strings:
http://en.wikipedia.org/wiki/C_string
Elseus
PostPosted: Wed Oct 29, 2008 3:57 am     Reply with quote
Is this your help ?
excuse me for I occupy you with my questions.
thank you very much for all...
