Interesting problem with hyperterminal
tranz
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Tue Oct 28, 2008 4:20 pm     Reply with quote
Hey Guys ,
I have an interesting problem with the RS232 terminal.
I am trying to send data via RS232 to a DSP controller. Now when I send the data through the computer at 9600 baud, the data is sent and the controller works.
But when i send this data via 18f4620 at 9600 baud, it does not seem to work. I am stumped, is there any difference between the computer based hyperterminal and a microcontroller based RS232.
Tranz
PostPosted: Tue Oct 28, 2008 4:29 pm     Reply with quote
1. Get a 2nd computer. Run the CCS program, SIOW.exe on it.
2. Connect your main computer to the 2nd computer. Run Hyperterminal
and send your data to the 2nd computer. Note the Hex characters
that are displayed by SIOW.exe.
3. Now connect your PIC to the 2nd computer. (remove the connection
made in step 2). Run the PIC program and look at the Hex characters
displayed on SIOW.
You should now be able to see the differences between the data
sent by Hyperterminal and your PIC.
newguy
PostPosted: Tue Oct 28, 2008 4:33 pm     Reply with quote
A quick question: do you have the TX and RX lines switched around on the PIC?
Freddie
PostPosted: Tue Oct 28, 2008 8:19 pm     Reply with quote
I never did like Hyperterminal. I use a free program called TeraTermPro v2.3. It works like champ.
http://hp.vector.co.jp/authors/VA002416/teraterm.html
tranz
PostPosted: Wed Oct 29, 2008 12:24 pm     Reply with quote
Gents,
The TX and RX lines are switched around on the PIC.
Here are the results of the tests carried out as suggested by PCM.
Yes there is a difference when the micro sends the data over RS232 than the computer, and the difference is when "FF" is sent over the RS232.
When the hyperterminal sends that data its "FF" but when the micro sends the data its "FF FF".
Rest of the data send does not seem to have this problem. Only in case of "FF" this error comes up, what do you think is the cause of this glitch, and how can I rectify this problem?
Tranz
PostPosted: Wed Oct 29, 2008 12:46 pm     Reply with quote
Post the PIC code that sends the FFFF.
tranz
PostPosted: Wed Oct 29, 2008 12:51 pm     Reply with quote
//settings
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7, STREAM=USER,parity=N,stop=1)
//the part of the code where in the data is sent from the TCP client to the //PIC and then the PIC sends that data to the RS232
int8 TCPConnectedTask(TCP_SOCKET socket, int8 which) {
   char c;
   if (TCPIsGetReady(socket)) {
      while (TCPGet(socket, &c))
     fputc(c,USER);//RS232
RLScott
PostPosted: Wed Oct 29, 2008 12:58 pm     Reply with quote
tranz wrote:
Gents,
...When the hyperterminal sends that data its "FF" but when the micro sends the data its "FF FF"...
Well, it's your program in the PIC that is misbehaving, isn't it? Look at your code and see if it is treating FF differently from other data.
One possible reason for doubling up on a certain character is when that character is an "escape" character in a binary protocol. Sometimes a special character is used as a delimiter in the protocol. If that special character happens to come up as part of the data, then you can send that character twice to indicate that it is just the character as data and not the character used as a delimiter.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
tranz
PostPosted: Wed Oct 29, 2008 1:12 pm     Reply with quote
Well I am sending a stream of binary data, and the only part the PIC plays is to transfer the data which it receives over Ethernet. So there are no conditions on what the PIC is supposed to display when it encounters a certain character.
If I need to send the character twice then that would corrupt the entire stream of data that I am trying to send. (about 7 KB)
Regards
Tranz
RLScott
PostPosted: Wed Oct 29, 2008 1:37 pm     Reply with quote
tranz wrote:
Well I am sending a stream of binary data, and the only part the PIC plays is to transfer the data which it receives over Ethernet. So there are no conditions on what the PIC is supposed to display when it encounters a certain character...
OK, then test that theory by eliminating the role of the Ethernet and do this:
      while (1)
         fputc('A',USER);//RS232
        fputc('B',USER);//RS232
        fputc('C',USER);//RS232
        fputc(0xFF,USER);//RS232
Robert Scott
tranz
PostPosted: Wed Oct 29, 2008 1:46 pm     Reply with quote
Yes with this test the PIC is displaying the data correctly. 0xFF is being displayed as FF.
RLScott
PostPosted: Wed Oct 29, 2008 2:26 pm     Reply with quote
OK, then the problem has nothing to do with RS-232. The problem has to do with how you get your data from the Ethernet stream.
Robert Scott
tranz
PostPosted: Wed Oct 29, 2008 2:38 pm     Reply with quote
Yes, certainly seems like that now. But the thing is that the micro is acting like a TCP/IP webserver and a client computer sends the data via hyperterminal based TCP/IP winsock.
All the micro is doing is to take the data and from ethernet and dump it on the RS232 terminal.
Any ideas about how to deal with this problem?
Regards
Tranz
