simple RS232 Questions
sadlpx
PostPosted: Tue Oct 28, 2008 9:04 am     Reply with quote
Having trouble with my RS232 using a MAX232 and need some help.
1. If I use the statement for hardware USART on 16F877,
I should have a normal high signal (5vdc) going low (with pattern ) during transmit. Correct???? that same signal should also be at pin 11 of the Max232???
PostPosted: Tue Oct 28, 2008 11:44 am     Reply with quote
That's correct.
ECACE
PostPosted: Tue Oct 28, 2008 11:47 am     Reply with quote
Correct. Remember though that the MAX232 has two channels for tx and two for rx. So it could be on 10 or 11, depending on how your board is wired up. Good luck.
A HW Engineer 'trying' to do SW !!! Run!!!
Rohit de Sa
PostPosted: Tue Oct 28, 2008 11:50 am     Reply with quote
As PCM Programmer confirmed, pin 11 on the MAX232 is a TTL input pin. The output of this pin will be an inverted voltage, about -13V, when input is 5V.
Rohit
sadlpx
PostPosted: Tue Oct 28, 2008 11:59 am     Reply with quote
Found my problem. I was getting poor signal out and did not understand.
Thought I had done something wrong in wiring. Problem turned out to be 1k resistor on 5v(p16). Eliminated resistor and all voltage input and output look fine.
Been gone a while and having problems. Next problem will be a new post thanks.
