RS232 problem, char routing through PIC
spom
PostPosted: Tue Oct 28, 2008 7:04 am     Reply with quote
I have a problem with RS232 and character routing through a PIC.
But now from beginning:
I use a bluetooth and a GSM module. For each I have a PIC. From my "main board" I send a character to the bluetooth/GSM PIC (via hardware rs232) and then via software rs232 to the according module. Following I send it back to my Computer via bluetooth or GSM. The problem is that I don't get the right characters, only each second (e.g. send: thisisatest; get: tiiaet).
Why?
For sending and receiving I use fputc and fgetc in a loop.
Do you need any further information?
Thanks.
P.s.: The help says something like "send it 10 times". But what does it mean? (Sorry, I have no help available now).
PostPosted: Tue Oct 28, 2008 12:05 pm     Reply with quote
Post the sending and receiving programs. Make them be very short,
like 10 lines in each program. Cut out all unnecessary lines of code,
The programs should have a #include, #fuses, #use delay, #use rs232,
and a main(). They must be compilable. Test the programs, verify
that they show the error, and then post them. They must be short.
Also post your compiler version.
spom
PostPosted: Wed Oct 29, 2008 4:14 am     Reply with quote
Below the code for the PIC on the GSM/bluetooth modul board:
#include <18f1320.h>
#fuses NOWDT,HS,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,INTRC
#use delay(internal=8M)
#use rs232(baud=2400,xmit=PIN_B3,rcv=PIN_B2,BRGH1OK,ERRORS,stream=TB)
#use rs232(baud=2400,xmit=PIN_B1,rcv=PIN_B4,BRGH1OK,stream=GSM)
while(kbhit(TB)){
c = fgetc(TB);
fputc(GSM,c);
The characters I send via Docklight, a HyperTerminal programm. TB is a hardware UART and GSM is the software UART.
RLScott
PostPosted: Wed Oct 29, 2008 6:25 am     Reply with quote
  while(kbhit(TB))
      c = fgetc(TB);
      fputc(GSM,c);
I have reformatted your code so that you can more easily see what is wrong. The "while(kbhit(TB))" loop is only satisfied as long as there is a character waiting to be read. After one character is handled, the code drops out of the loop and then clean off the end of the main() program. From there it somehow finds its way back to the beginning of the program where it re-initializes everything. In the meantime you have missed an incoming character, which is why you get every other character. I think what you really wanted was:
     if(kbhit(TB))
        c = fgetc(TB);
        fputc(GSM,c);
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
spom
PostPosted: Wed Oct 29, 2008 7:35 am     Reply with quote
Thanks.
I tried it that way but I still have the same problem. I also tried to change baud rate but with no effect. I tried to use a buffer - no effect.
I think the problem is in the software UART....
ECACE
PostPosted: Wed Oct 29, 2008 10:20 am     Reply with quote
For the SW #use RS232, add FORCE_SW to it. It should be able to figure it out, just in case it didn't though, add it in there. Also, are you sure that it's not a HW problem? If possible, write a small program to send out via RS-232 a count. Then connect it to a terminal program and make sure that both sides can send out to the terminal correctly. I suggest you do only one at a time. Just to rule out an HW problem, and that the UART's SW+HW are working.
A HW Engineer 'trying' to do SW !!! Run!!!
